Equipment Racks
1568101118
    Clipdat Posts: 12,560
    From a design and engineering standpoint, is having a rigid one-piece square frame like this going to be more effective toward combating wobble?
    In my mind, this design looks a lot more rigid than the VTI, but I'm still not clear on why.
    marvda1 wrote: »
    here's the adona entry level racks.
    http://www.adonacorporation.com/modular.html
  • marvda1
    marvda1 Posts: 4,862
    Clipdat wrote: »
    marvda1 wrote: »
    don't believe this is a one piece welded frame, but i had an old target welded stand and it was rock solid. adona's been around a while, heavy and well built
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • Joey_V
    Joey_V Posts: 8,505
    Clipdat wrote: »
    A local shop carries Salamander and Core Audio Designs, so I might go check them out in person to see about their stability.
    http://coreaudiodesigns.com/products/component-racks/
    I’m familiar with core racks. You do know it’s a completely different price point?
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    You're right, it's not a one-piece frame, just looked at the assembly instructions.
    Still, it just looks inherently more stable to me for some reason. But looks can be deceiving.
    marvda1 wrote: »
    Yes, I see that. Not sure I can swing for something that expensive, but it would still be nice to check them out in person at the local shop and see how they look/feel.
    It seems like most people must be happy with a 2-3 shelf unit, because once you start looking at 4-5 shelf the prices go way up. :/
    Joey_V wrote: »
    Clipdat wrote: »
  • marvda1
    how many shelves do you need?
    Puritan PSM156
    How many I "need" might be different than how many I "want"! :D
    Ideally 5, could go with 4 if I had to.
    I have three CD players that I like to have hooked up at the same time. I'm a weirdo.
    marvda1 wrote: »
  • marvda1
    this one is $1740 right now.
    http://www.adonacorporation.com/av45cs4.html
    Puritan PSM156
  • kharp1
    kharp1 Posts: 3,453
    The Adona racks use an aluminum multi-channel system. It's a very solid system. We use this at work, at times, for mounting different pieces of equipment. I've often eyeball it with thoughts of sneaking out enough to build a nice rack, but, my job isn't worth it. You can but these pieces, and harware, from suppliers, but, it is expensive. That's why work doesn't keep much on hand. They pay at least double for anything they buy.
    Plus, Adona uses some different materials for their shelves to aid in sound deadening.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Interesting. Well, I have a bubble level like this that I got for my TT:
    https://cdn.shopify.com/s/files/1/0105/4542/products/ortofon-bubblelevel_1200x.jpg?v=1421686419
    verb wrote: »
    Yep you would. You could mark the threaded rod, but any fine tuning to get em level would require turning the nuts a bit. I believe they are a continuous shaft.
    Perfect!
  • verb
    verb Posts: 10,176
    marvda1 wrote: »
    Clipdat wrote: »
    marvda1 wrote: »
    The advantage of this unit is that it is bolt together. That way you can ensure everything is true and square prior to tightening everything down.
    F1nut Posts: 49,711
    Clipdat wrote: »
    One word, ADONA
    The hype is real.
    I wonder if they have a "wobble free guarantee".
    One word, ADONA
    txcoastal1 Posts: 13,124
    Clipdat wrote: »
    The hype is real.
    One word, ADONA
    No wobble, no schmutz, no hum :)
    This reminds me of Larry's rack...
    vs
    marvda1 wrote: »
  • Joey_V
    Joey_V Posts: 8,505
    That’s a pretty serious rack
  • verb
    verb Posts: 10,176
    All of you Adona lovers (of which I am one), but can't seem to pull the trigger on 2 large for a rack, check out this site:
    https://www.8020.net/
    Adona uses a lot of 80/20's components to build their racks!
    Nice resource for those who have great design "vision" and DIY skills.
    verb wrote: »
    verb wrote: »
    I like it
    3-shelf unit 40"Hx20"Dx20"W pending on shelf material probably $700
  • verb
    verb Posts: 10,176
    txcoastal1 wrote: »
    verb wrote: »
    I like it
    Yep. I've actually bought stuff from them. And they sell parts on eBay, odds and ends of different pre-cut lengths. They will even cut them to length for you if needed. I use a metal cutting blade on my tablesaw to cut the aluminum rails.
    I calc'd 4-40" and 12-20", gazed over the mounting accessories, and included the end taps
  • verb
    verb Posts: 10,176
    Cool! Sounds like a DIY Adona Rack coming soon! :smile:
  • kharp1
    kharp1 Posts: 3,453
    txcoastal1 wrote: »
    I've browsed them before, I think the accessories are what really hurt with hits stuff if I remember correctly.
    kharp1 wrote: »
    txcoastal1 wrote: »
    Correct the posts and cross members were calc'd at $296, the accessories and shelves is the remainder of the cost
  • mrbiron
    mrbiron Posts: 5,711
    verb wrote: »
    Since i am not at home, can anyone confirm that salamander uses similar hardware to what is found on this site?
    If so, this is most excellent!
    I’ve wanted to add two shelves to the sides of my Synergy cabinet. One for my PC and the other for my headphone amp (ran out of room inside).
    EndersShadow Posts: 17,517
    mrbiron wrote: »
    verb wrote: »
    Is this what your looking for?
    http://www.audioadvisor.com/prodinfo.asp?number=SMSAEZN
    How do you like the Synergy? Any pics?
    mrbiron wrote: »
    verb wrote: »
  • mrbiron
    I like my Synergy single a lot. Absolutely solid construction and nice finish.
    What I would like to do is add two shelves to the outside. One for my headphone amp and the other for the PC.
    Older picture but not much has changed...
  • marvda1
    Puritan PSM156
  • mikeyb128
    mikeyb128 Posts: 2,885
    Don’t forget about solid tech. They have a new hybrid rack, completely customizable, and has several different configurations to suit your needs. You can buy each individual piece, and add on to the rack as your system grows. The quality is top notch, and very precise. There was absolutely zero messing around while assembling. The machining of the aluminum parts is very high quality. Even the way they pack this think is stunning. There are several color options as well.
    It’s very solid, You could do a back flip in the living room and land on your head, and get no skips from vinyl playback.
    http://www.solid-tech.net/hybrid/
    2 channel:
    Theater:
  • verb
    verb Posts: 10,176
    edited March 2018
    verb wrote: »
    Sorry but I'm quoting myself! So I did a parts list using 80/20 extruded rails, pre-cut. Overall dimensions of the project will be using 5 shelves that are 24" wide, 21" deep. Overall height of the rack is 36" (excluding feet).
    If you buy bulk lengths of the rail it would be a bit cheaper. Would have to cut with a metal cutting saw of course.
    Price including shipping (sans shelves):
    Similar to the Eris model 5C ($2600). The shelves could be bolted directly onto the rails, or you could isolate them in a similar way that Adona does. Key here is flexibility, and this design makes future upgrades (bolt em down now, isolate later) add wings, etc. possible.
    Considerable savings here, and the joy of another DIY project!
    FWIW!
