AV receiver for Polk LSiM 703,707,706
Ross99Ross99 Posts: 5
I want to buy a 5.0 system of LSiM 703,707,706 for my home theater.
Do you have a similar set up? What amps/receivers are you using? what di you recommend?
Would be great to get some feedback!
Answers
  • Jimbo18Jimbo18 Posts: 1,725
    Ross, Most people on here are going to advise you that a receiver is not going to have enough power to drive that setup very well. There are various power amplifiers that you can find recommended in the forum.
    Modest HT - Pio Elite SC-63, RT800i, CS400i center, RT25i surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Premiere+
  • Ross99Ross99 Posts: 5
    Hi Jimbo
    Thanks for your reply
    I am quite new to this and I am walking blind :neutral: would be great to get any advice..
    I looked at Yamaha RX-A3070 or denon 3400.. something that is ca $2000 but I'm not sure if this is a good choice..
    Thanks!
  • tonybtonyb Posts: 29,083
    The Yamaha is a great choice, and should drive those speakers well. All speakers can benefit from some good clean current a separate amp provides, but your best bet is to try it first with a receiver of that Yamaha's caliber, and then see how you like it. Can always add an amplifier later if you think you need more power.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • mlistens03mlistens03 Posts: 1,042
    edited March 3
    The speakers could be powered by those receivers, but they would never be able to deliver what they are truely capable of. In other words it would work, but it probably wouldn’t sound great, and wouldn’t necessarily safe for either the speakers or receiver. They would be better off with a 7 channel amplifier (it won’t have volume control, so you will still need to buy a receiver or a HT processor, that has full preamp outputs) and then just bypass the built in amps on the receiver you use.
    I personally use a Crown XLi 800 power amplifier, which I really like, but it is only a 2 channel, so you would have to buy 2 or 3 to power the whole setup. And it is a professional amplifier, that would be used for concerts and the like. I personally think it sounds great, but others here would argue that comment. The real selling point for me is that it was cheap, and I mean like $200 a piece new.
    Used is also not a bad thing, almost everything other than my amplifier in my setup is used, and it still sounds great. So I would look on your local Craigslist and eBay, and see what there is in your area. If you are looking for a good (not amazing) receiver that you can probably find for cheap, you could get a Yamaha rx-v665, which is what I use. It has full preamp outputs, and sounds nice, and for serious listening has a pure direct mode, with no filters in the amp being used.
    While I would like to think of myself as knowledgeable on this subject, i am really just starting to get into high end audio, buying my first good pair of speakers in summer 2017, so there are probably people who know a lot more about this stuff that could help more than me.
    Micah
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • rpf65rpf65 Posts: 1,663
    Both of those AVR's will run your set-up. I ran the 705's and 706 with a Yamaha RX-A2060 for a short while before adding an amp. Very noticible improvement in sound quality after adding the amp. Sound quality is the reason for adding amps, although you can safely run them at higher volumes.
    They use different calibration programs. Many fans of Audyssey, which Denon uses, but I personally didn't feel there was much difference from YPAO. Neither was perfect, and I made slight changes to both of their final results.
    If your going to use an AVR to power your speakers, just be careful with the volume knob.
    Many thanks! so let's say I will go with Yamaha RX-A3070 or RX-A2070.
    Now sorry for a newbie question..How would I connect the Amp? source->amp->AVR->Speakers?
    what amp would you recommend? rpf65 what amp are you using? thanks!
  • mdaudioguymdaudioguy Posts: 4,367
    source->AVR->amp->speakers
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
    so what amp would you suggest for this setup? :smile:
    Lots of brand recommendations on here if you read up. Maybe consider a 2 or 3-channel amp to keep the cost reasonable, if that's a concern. Connect the amp to front left and right (and center, if 3-channel). Connect surrounds (and center, if 2-channel) to AVR. A nice AVR such as what you're considering can handle the reduced load just fine.
    thanks mdaudioguy
    So what you're saying is avr for surround + stereo amp for fronts. The part where I'm still lost is that sound would still go through avr and than to amp. Is there some kind of pass-through in avr's? or how does it work?
    Also it is quite a lot of kit and I do not have a lot of space..
    I have looked through the forums and found following amplifiers as recoomendations:
    • Cambridge Audio CXR 200
    • Onkyo TX-RZ1100
    • Marantz SR6011
    • Arcam FMJ AVR390
    • Primare SPA23
    some of them really pricey.. any thoughts, recommendations, experiences?
    Would be great if I can fit around $2000
    Thanks!
    You seem to be confusing AVRs and amplifiers. Your list includes several AVRs. An AVR needs pre-out connections on back to output any or all of its channels to an external amp. The Yamaha AVR models you mentioned above are good options with pre-outs. Amplifiers have an input for each channel. You'll need an interconnect (IC) cable for each channel you want to send to an external amp.
  • cfrizzcfrizz Posts: 12,912
    edited March 3
    mdaudioguy wrote: »
    Welcome Ross! To expand on the above....
    You will run the speaker wires directly to the amplifier, you will use IC's from the amplifier to the Preouts on the receiver. The speakers are powered totally by the amplifier.
    Get the Yamaha RX-A3070 or RX-A2070 which has preouts and go from there.
    Post edited by cfrizz on
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
    http://www.audioadvisor.com/prodinfo.asp?number=PAC2250V2
    http://www.audioadvisor.com/prodinfo.asp?number=PAC2125V2
    https://www.musicdirect.com/power-amp/NAD-C-268-Stereo-Power-Amplifier
    Here are a few budget friendly amps that should work. There is also the used market, if you're not opposed to that.
    Curious as to why you don't want to run a sub?
    edited March 3
    I might get some hate for this one, but for your fronts you could use a Crown XLi 800 professional amplifier, which is what I use in my setup. It actually sound pretty nice, but it is probably no match for a real home audio amplifier. But, if you have to buy new, and you need something cheap, this is a good option (I think anyway)
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • bikerboybikerboy Posts: 1,136
    Buy my B & K Reference 200.5 and a receiver with Preamp out puts! !!!!!!!
    D:Sonore UltraRendu usb w/LPS-1->Amanero I2S converter ->I2S->TPA Buffalo 9028 w Mercury output dac w Salas ps->BAT VK-51SE w/BP Preamp via XLR to BAT VK-200-> Polk LSiM 703
    A:Dynavector DV-10x5-> Nothingham Spacedeck-> TPA Retro via XLR to Relaixed2;
    V:Vinyl rips-> ESI [email protected]/192
    SACD: Denon 3910
  • Gerres26Gerres26 Posts: 310
    bikerboy wrote: »
    I have a minty B&K reference 20 pre/pro that would match up nicely with his 200.5. Let me know if interested.
  • mrlorenmrloren Posts: 1,341
    Frist get a good AV Receiver like the Yamaha 2070 or 3070. maybe look for a deal on the 1060/2060/3060. Marantz are also nice AVR the 6011 would do you nice.
    Once you have the AVR setup, save some coin for a good amp.
    B & K
    Parasound
    or even Emotiva
    Once you have the amp you will need good RCA cables to run from the AVR to the amp. You will remove the speakers from the AVR and hook them to the amp. This will turn your AVR into a pre-amp processor.
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S30
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
Howdy, Stranger!
