Polk psw-10 chip
I was wondering if someone knew the model number for the amp chip for the Polk psw-10 mine is charred so I can't read it.
Best Answer
Answers
  • tonybtonyb Posts: 29,943
    Not sure what you mean by a "chip". Possibly a resistor on the board ? Chances are, if a resistor is burned up, something else is also. Pictures tell more, if that's possible.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
  • you2314you2314 Posts: 3
    edited February 27
    tonyb wrote: »
    The one with the heat sink on it. I will send some pictures later
  • KennethSwaugerKennethSwauger Moderator Posts: 6,648
    In all likelihood that is the amplifier IC, usually called an "STK amp" since the part number start with STK.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
    That what is is. What is the model number
Howdy, Stranger!
