Polk psw-10 chip
you2314
I was wondering if someone knew the model number for the amp chip for the Polk psw-10 mine is charred so I can't read it.
Best Answer
TDA7294
Answers
Not sure what you mean by a "chip". Possibly a resistor on the board ? Chances are, if a resistor is burned up, something else is also. Pictures tell more, if that's possible.HT SYSTEM-
lsi 9's -
The one with the heat sink on it. I will send some pictures later -
In all likelihood that is the amplifier IC, usually called an "STK amp" since the part number start with STK.
KennethSwauger wrote: »In all likelihood that is the amplifier IC, usually called an "STK amp" since the part number start with STK.
That what is is. What is the model number
