Vibration Pods Recomendations
gudnoyez
Audio Advisor offers Vibration pods. I want to place them them under my DAC that sits on my desktop to reduce vibration from the speakers that are placed a few feet away. AA has about 6 different types, looking for recommendations from someone using them.
pangea sorbathane
I saw those they have adhesive backing and some clear disc that goes underneath only you adhere them to the sides of the stock feet, while others you place under the feet. If you have them do they still look presentable underneath with the stock feet just hanging there? I had the tunes pretty loud the other night and started worrying about the DAC subcoming to excessive vibration.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Steve, I am going to text you some pictures and post them up here with what I use with my Shciit Sys.
They are the 1/2" Sorbothane hemispheres and I got them off Amazon. I also have them on a couple of CD players, my Peachtree DACiT and have the HUGE ones for my turntable.
They are dirt cheap on Amazon and great.
They are available in a HUGE array of sizes...
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=Sorbothane+feet
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I do not know about adhesive sorbothane is sticky by nature. the disc is to keep them from sticking to furniture or shelving. I've used Audioquest sorbothane for years big believer in its ability to stop vibration. it will always be under any CD/SACD player i ever have. I will buy the pangea the next time its cheaper and works the same way. The feet from pangea I seen at RMAF had no adhesive what so ever. I in most cases do not put them under the feet I will put them beside if possible
Sorbothane is extremely effective at preventing vibrations transfering from the surface your gear sits on, but do not let it come in direct contact with any finished furniture surface as it will leave a stain.Political Correctness'.........defined
President of Club Polk -
Thanks for the input guys, your the best. I am going to order both the Isolate IT ones, and the Pangea ones to compare, I have a lot of stuff that needs isolating anyways.Home Theater
Yep agree. Mine has always been on metal or laminated surfaces so that was never a concern. -
don't forget herbies. http://herbiesaudiolab.net/Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
I do love my Herbie's TT mat..."Some people find it easier to be conceited rather than correct."
I got ur vibration pod...right here!! Sorry, its the beer talking.
If you use the pods make sure they are sized for the weight.
afterburnt wrote: »If you use the pods make sure they are sized for the weight.
Great advice as that is very important.Political Correctness'.........defined
Cancelled first order and got these instead set of 4ea
https://www.isolateit.com/hemispheres/sorbothane-hemispheres-bumpers/0-5-sorbothane-hemisphere-0510101.html
Also ordered a Wireworld Starlight 7 1.0 meter USB cable so the Isolate IT hemisphere bumpers qualified for free shipping from AmazonHome Theater
Took Ryan's advise and got these I can see why I will need wax paper under these, I will have to get some before I apply them, these are beefy and I'm sure they will serve their purpose.
Waiting to hear what you think about them. I had ordered some Vibrapods, but, I'm not real enthused about them.
Years ago I tried them, Sorbothane works way better. I believe the Vibrapods went out with the trash.Political Correctness'.........defined
Never liked vibrapods, mine also went the way of the dodo
Worked way better as in better SQ?Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
As in way better isolation of components. I first tried vibrapods because I had a CD player that skipped pretty much all the time when my kids and dog were running through the house. They didn't work so well and I had a local place sell me the first generation of audioquest sorbothane pucks put those under my CD player and I could body-slam anybody in that room and it would never skip at all. Made me a firm believer. When I bought the autoquest sorbothane pods again this time they were in the big hemispheres and little hemispheres and I bought four sets of four of those from HCM audio for half price when they were clearing them out. -
Ed ZacharyPolitical Correctness'.........defined
I would very highly suggest some Marigo Audio Labs Mystery Feet, here: http://marigoaudio.com/isolation-feet/mystery-feet/
These have made a massive difference in isolation (clarity, detail,etc.) Compared to any other isolation feet I have used. They are expensive, so I suggest buying used. They don't wear out. These, IMO will be the last isolation feet you ever buy.
