Help! I need to spend money! Cables?
afterburnt
I have so few things left that I want to do beyond a cheap phono stage and maybe a dac (or a bigger badder Aries) I am getting some power cables for the HT but that's the only thing for sure. What am I missing other than brains?
Depends on what you are trying to do and how much you are looking to spend. Have you addressed other aspects in the room and system prior to the cables? Room treatments, etc?
I would say power cables do make a difference, however.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
single-ended triodes? got any single-ended triodes?
mhardy6647 wrote: »single-ended triodes? got any single-ended triodes?
I hope not, I am due for a physical in March. -
There's no cure -- I'll warn you now.
Jerry Lewis was gonna do a telethon -- but he died instead.
Jerry's on the corner now
And if you want to be a junkie, wow !
Just remember
Jerry's dead -
Joey, I'm going to be moving so not working on the room, it's beyond help anyway. I did want to ask you how you attached that panel to your ceiling? -
Ya know I only get out of the "happy with what I got" rut when I upgrade something.
No doubt, the best route to be happy with what I've got is to have as much as possible.
Wait what ?? You need US to help spend YOUR money ?
Dude....you came to the right place.
