Phono Pre-Amp Suggestions
  • SCompRacerSCompRacer Posts: 6,740
    edited February 15
    FWIW, I've heard impressive results from the Music Hall PA 1.2 phono pre. IIRC it's in the buck fifty range. A friend has one. He upgraded his turntable with one purchased from me and it sounded good.
    We first tried it with my table and his cartridge and then an upgraded cartridge. It made the improvements known.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • kharp1kharp1 Posts: 2,341
    When I started my research phase for vinyl I looked at a lot of different ways to approach it and I realized that something like the Vista was important for me due to the many levels of gain and resistance as well as filtering in and out. I had really wanted the Zen Decware Triode, but, that would have required a seperate SUT bringing the total price to around $1300. I wasn't prepared to pay that unless it really panned out. Figures I could always sell the Vista and go the triode route at a later date if it worked out.
    There are several out there that have a wide range of settings, which I think is important if you even remotely think you may change carts, so, so your research.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • maxwardmaxward Posts: 101
    If the OP is still looking, another one to consider used is a Jolida JD-9 (original version). It has lots of gain/loading options and responds well to upgrades.
    Thorens TD-160C; Sumiko Talisman S; Jolida JD9; Marantz CD-53; Micromega Mydac
    Joule-Electra LA-100; Balanced Power Technology AC conditioner;
    Odyssey Khartago monos (with most factory upgrades); Magnepan MG 3.6R
  • dr1978dr1978 Posts: 185
    Still looking and I'll take that under consideration. I'm having a hard time finding anything on the original version though.
    Lounge LCR MKIII, AMC 2100, Marantz SR5011, Polk LSiM705, Polk LSiM706C, Polk RM8, Polk PSW450, Pro-ject 2 Experience SB, OPPO BDP-103
    There is a review here: https://positive-feedback.com/Issue65/reader2.htm
    Probably some others out there as well. I’m happy with mine. New issue Mullard tubes improved it. Good luck.
    Thanks!
  • vcwatkinsvcwatkins Posts: 1,647
    I really like the Lounge LCR. New mkIII's go for $300ish I believe. Very good sound, great value, and if you want to explore beyond MM, you can pair later with the Lounge Copla SUT. There was a short, positive write-up of the Lounge in recent magazine. I'll look around to see if I can find it.
    Here is a used MkII on eBay for $175 shipped.
    Although I've never heard one, I'd also be tempted to build a Bugle shown in @mhardy6647's post above.
    Den: Rega RP6 (mods) * AT33PTGII * Parks Budgie SUT * Jolida jd9 (mods) * Roon (Sonic Transporter) * Sonore UltraRendu (LPS-1) * Wireworld Plat7 * isoRegen (LPS-1) * Lush usb * PS Audio DirectStream Jr. * Joule-Electra LA-100 iii * Sunfire Sig II * PSAudio p3 * MIT S3 * Polk SRS 1.2 (mods)
    Office Rip: Music Hall MMF5.1se * Speed Box II * DL103r * Lounge Copla SUT * PS Audio NPC * Roon * Bryston bdp-1, Bryston bda-1 * Rogue Cronus Magnum ii * PSA Dectet * MIT s3 * LSA-1 Statement
    Beach: MH mmf2.1 * Denon dl-110 * Belles Phono 20a * Sonos * Chord QuteEX (Pardo PS) * Belles 20a * Pass Aleph 30 * PSAudio Dectet * MIT s3 * Polk SRS 2.3tl (mods) - Revel M22
  • mpitogompitogo Posts: 253
    So funny you are looking for a pre and this gent has a pre and looking for a TT. http://forum.polkaudio.com/discussion/180767/moar-turntable-talk#latest
    I had a physical look at the project tube box today picking up a few albums, I didn’t realize it was adjustable. The dips are at the bottom.
    Music-2.0 Raidho D-3.1 | Audio Research Ref 40 | Jeff Roland 925 | Esoteric Grandioso K1 | Transparent Reference, IC, Speaker and Power | HRS SXR Rack
  • JaybeezJaybeez Posts: 659
    I have the Lounge and love it.
    Living Room (HT):Denon AVR X-3000 ; LSiM 703 ; LSiM 704C ; FXi4s ; Sub – Rhythmik F12SE
    2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Ascend Acoustics Sierra 2s ; Polk PSW 350 Sub
    "And these children that you spit on, as they try to change their worlds, are immune to your consultations. They're quite aware of what they're going through."
    mpitogo wrote: »
    Match making at it's finest. That's one of the things we do well here...and help you spend your money.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    vcwatkins wrote: »
    Stereophile Feb 8, 2018
    https://www.stereophile.com/content/gramophone-dreams-20-lounge-audio-mofi-ultradeck
    edited February 18
    How did I double post?... Just in dL-110 my first MC. Due to lack of MC pre start by trying out what a high output MC can do before getting SUT or MC pre before trying out a low output cart.
    Post edited by KennethSwauger on
  • afterburntafterburnt Posts: 4,389
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
    Thanks everything for all of your opinions and advice!
    I ended up going with the Lounge LCR MKIII. Purchased it off a fellow Polkie at a very fair price. Can't wait to fire it up!
  • ClipdatClipdat Posts: 3,582
    Nice choice. IMO that level of preamp fits nicely alongside the high end TT and cartridge that you got.
    Talk about a badass first vinyl setup, sweet!
    dr1978 wrote: »
    Got Dayens?
Howdy, Stranger!
