Looking for replacement MW6511 for SDA 2.3
prosuite
Hey guys, Looking for a 6511. Anyone got one? I know you can get allot of these new but I bought one before for a different set and it looks allot different than the originals and sticks out like a sore thumb... or a new speaker amongst a wall of classic ones to be more accurate.
Tim
Tim,
Keep an eye out on Ebay. You may be forced to buy a set of 4, that way it will match cosmetically. Of course the other solution is to put the grills on. {;o)
And I can highly recommend doing what I've just done to my set of 2.3s. Hurricane nuts, rebedding the speakers, and a bit of sonic foam. Great bang for the buck!
Cheers,
R*2SDA SRS 2.3s
Pair of Carver TFM 35s
Carver C-1 Preamp
CAL Icon MkII CD
RTA 12s, need major work -
Yep agree. You can create a search for mw6511 so that eBay will notify you as soon as one is listed. Or you can wait for Karma. I recently gave one away!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Is there a list somewhere of all the different 65xx's and their model number designation?
Start using the link below. Best portal to the world of SDA mods!
http://forum.polkaudio.com/discussion/133384/all-the-polk-sda-upgrades-located-in-one-place/p1Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Tim,
Cheers,
R*2
Thanks for the info. where do I read more about that?
Any comment about SL2000 tweeters vs the upgraded ones? Im pretty happy with these. its hard to imagine anything better. Just got these things working proper. -
Also, I should mention Polk audio here in Canada still sells replacement SL2000s and the replacements for SL3000s for the same price -
Tim,
Cheers,
R*2
Yeah, they are horrible. Get the new ones.Political Correctness'.........defined
