Black Hole 5?
I've found using a long straight edge that I clamped down onto the material. Then carefully slicing my way through with a utility knife works well. But that's for us metal workers who don't have table saws.The Night is Dark and Full of Terrors
Good idea. Clamping down I’m assuming compresses the foam a bit making it easier to cut. And holding it in place.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
A heavy aluminum straightedge and a SHARP kitchen knife. Worked like a charm, no fooling around with nasty noisy dangerous circular blades spinning at thousands of rpms.
Lol, I've got a table saw. Just cut a straight line with a long sharp blade.SDA SRS 2.3s
Pair of Carver TFM 35s
Carver C-1 Preamp
CAL Icon MkII CD
RTA 12s, need major work -
Yeah it's freezing in the garage! No furnace in there yet like I had at the old place. Recently moved to a new home. Cold weather is de-motivating for working on projects in there! Got a kerosene bullet heater, but still a pain in the arse. I'll give it a go!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
