Schmutz/residue on LSiM 703 tweeter
I purchased my 703s directly from Polk and I immediately noticed that one of the ring tweeters had some white schmutz or residue on it in the valley/channel of the ring.
The other speaker's tweeter didn't have this. I tried very gently wiping it with a soft microfiber towel, and it would not come off, so I stopped trying. I think it might be something from the white cloth bag that the speaker ships in, as I noticed that it was touching the tweeter when I unboxed it. So maybe the speaker was packaged when the tweeter was still sticky for some reason and then it got some of the fibers of the white bag stuck to it?
Or maybe just the fact that it was in contact with it through the shipping process and being exposed to various temperature changes caused it. Or perhaps I just got "unlucky" and they came like this from the factory - if you look closely on the second photo of speaker A, you can see that there's also some residue on the soft rubber trim that surrounds the tweeter.
Anyway, not a huge deal as it doesn't seem to be affecting the audio reproduction, but just figured I'd show it alongside the other one and see what everything thinks.
Speaker "A" schmutz:
Speaker "B" normal:
Speaker "B" normal:
I think you need to consult someone who speaks Yiddish.
Try a firm paint brush to remove it.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
Thanks, I'll try this but it seems fairly stuck on there.
Do you know if the sound is actually coming from the black rings/waves, or if it's coming from behind it?Try a firm paint brush to remove it.
Maybe some Windex on a q tip?
Is that safe for that material of the tweeter? Didn't want to put anything wet on the tweeter.ken brydson wrote: »Maybe some Windex on a q tip?
It's safe.Political Correctness'.........defined
President of Club Polk -
If a brush won't get it then a damp Q-Tip as stated would be fine. Even better would be one of those foam eyeshadow brushes. I grew up with Mom and two Sisters now I have a Wife and Daughter. Some of their makeup tools are handy for projects.
2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
I haven't done anything yet, I'm just super tentative to try to use any sort of liquid or exert any pressure on the rings of the tweeter.
After paying this much for these I'm just a bit gun-shy. I actually emailed Polk CS about this and sent the same pics just to see what they have to say.
Worst case scenario I just keep the grills on and forget it's there?If a brush won't get it then a damp Q-Tip as stated would be fine. Even better would be one of those foam eyeshadow brushes. I grew up with Mom and two Sisters now I have a Wife and Daughter. Some of their makeup tools are handy for projects.
Yes, by all means...if you don't feel comfortable doing it, then just leave them alone. In most cases there is not a major risk if one is careful however you don't want to be the one to damage a new set of speakers.
See what Polk says and if they won't replace it then just try to ignore it. The truth is, many dome tweeters collect dust anyway if you leave the grills off. So at some point they need to be blown or suctioned off. Else they will look just like yours or worst!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
I've not yet heard anything back from Polk CS regarding this, I sent them the email on 12/26.See what Polk says
FWIW the rubber surrounds on my 705 towers were cleaned (gently) with Windex and a soft cloth as has been mentioned just prior to my purchasing them and have suffered no ill effects. I do understand your hesitance to try it, don't get me wrong, but I've seen it mentioned here many times as the "go to" solution for white schmutz.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I understand for the surrounds, but I'm hesitant to put any cleaning liquid on (what I'm presuming to be) the delicate tweeter material that actually makes the high frequency sounds.FWIW the rubber surrounds on my 705 towers were cleaned (gently) with Windex and a soft cloth as has been mentioned just prior to my purchasing them and have suffered no ill effects. I do understand your hesitance to try it, don't get me wrong, but I've seen it mentioned here many times as the "go to" solution for white schmutz.
It's not as delicate as you think. Try the Windex.Political Correctness'.........defined
One thing I'm still unclear on, does the sound actually originate from the black material with the two rings/ridges/waves, or does it come from what appears to be a copper colored drive unit behind it?It's not as delicate as you think. Try the Windex.
BothPolitical Correctness'.........defined
You are confusing that with chicken fat. -
I emailed them again on 1/17 and never heard back, so I just emailed them today for a third time regarding this.
Try calling.Political Correctness'.........defined
I could try calling, good point.
But they could also try replying to an email sent nearly 3 months ago.Try calling.
The last time I saw sticky stuff on my tweeter...well, nevermind.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Go on....Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Schmutz on the ol' tweeter eh.....Was Russ in your area recently ?HT SYSTEM-
lsi 9's -
I never kiss and tell....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Finally got a response from Polk CS to my inquiry about this that I sent on December 26th! It only took them ~2 months to reply!
"Response By Email (Tom C.) (03/05/2018 06:39 AM)
Hello Drew,
That is nothing I have seen before. I am not sure what could have caused it. If you have any questions or concerns you can give us a call at 1-800-377-7655 so we can get you the assistance you require.
Tom Carter
Customer Service Technician
11500 Cronridge Dr
Suite 110
Owings Mills, MD 21117
www.soundunited.com"
