Sennheiser HD800s cable build
ALL212
Had the Mainline hooked to the 650’s and was happy with the bass (some complain that the Mainline is bass weak). Thought about that as I usually listen with the 800’s. Realized that I was using a stock cable with the 800’s.
So... Sir Halo and I traded services for the last 12 feet of the cloth techflex leftovers and I bought the Furutech 800 ends and 1/4 plug.
High heat is the trick on the Furutech 1/4 end and pre-tin the microfrickinscopic 800 end pins. Breaking in now but it’s better by a long shot. WTF with stock cables?!
The microfrickinscopic end compared to an rca end that was laying around. This was the easy end!
Aaron
Enabler Extraordinaire
Nice work, Aaron. Mildly envious of your stable of headphones and related gear.Jay
Those look really sweet! Glad they are an improvement over the stock cables.
Is anything you own still "stock?"Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
