WTB - 1.5 meter interconnects
Jaybeez
I have some Audio Quest Black Mamba II RCA Interconnect cables I am getting ready to list. They are 2m long. Purchased them a little less than 2 years ago from Audio Advisor: http://www.audioadvisor.com/prodinfo.asp?number=AQBMII
Polkie price including USPS Priority shipping $65?
Let me know if these are something you would be interested in and I can pictures in the morning. I am at work right now and do not have access to them.2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Speakers: Golden Ear Triton Reference
Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90/JBL SDP-55
Amps: Parasound A31, A51x2
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Audio Advisors King Cobra cable. Good stuff at a great price.
This would work perfectly PM coming. -
Are these for use from the TT to phono pre, or phono pre to preamp?I disabled signatures.
TT to integrated. Phono stage on integrated as good as my phono pre, so phono pre is redundant.
@Jaybeez
Replied to your PM.2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Why do you want audio cables for your turntable? Are you using a moving coil cart?Component video cables have lower capacitance and sound better with moving magnet carts. Lower capacitance is better for MM carts. If you are using a MC cart, lower capacitance cables are not necessary. I had AQ audio cables on my turntables until about 6 or 7 years ago, when I replaced them with cheap low capacitance video cables. They sounded better than the Audioquest cables. Always keep the cable length to the phono stage at 6' or less.Main System:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8 & FB210 ~ Martin Logan Dynamo ~ Teac R-919X ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater:
Vizio V585-H11 ~ Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Marantz DV6001 ~ EPI M90 ~ Polk Audio RT35i ~ CS400i ~ (2) Polk Audio PSW450 -
classic carl wrote: »Why do you want audio cables for your turntable? Are you using a moving coil cart?Component video cables have lower capacitance and sound better with moving magnet carts. Lower capacitance is better for MM carts. If you are using a MC cart, lower capacitance cables are not necessary. I had AQ audio cables on my turntables until about 6 or 7 years ago, when I replaced them with cheap low capacitance video cables. They sounded better than the Audioquest cables. Always keep the cable length to the phono stage at 6' or less.
I've always used audio cables for this TT. Wasn't aware there were other viable options.
