RDO-194 Break In
  • hauxon
    hauxon Posts: 161
    Panflute music works best. Two months since TL modding my 2Bs and I'm almost broken.
    But seriously the RD0-198 sounded great frim the start.
    SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint
  • scubalab
    scubalab Posts: 3,101
    Well it was a Doobie bros. concert lol
    I know a guy in the Bahamas named Doobie. Pretty sure I know what line of work he’s in...
  • oldschlpolkie
    I just replaced a pair of RDO-198s myself and I’ll be spending the weekend burning them in with a little mix of everything. So far they sound much better than the 2500s that I just pulled out and as westmassguy said they made me smile.
  • verb
    verb Posts: 10,176
    Yep. Been playing for a few weeks. Not constantly, just normal play. Love em!
  • oldschlpolkie
    If you want some real good quality recordings and great music check out the music from mapleshaderecords.com. I’ll be playing several of those this weekend.
  • verb
    verb Posts: 10,176
    I've heard that running Pink Noise through the speakers facilitates burn in. What do you guys think? Yes, yes I know the break in journey is fun, just playing music, loud, ignoring the wife to turn it down, but thoughts?
    pitdogg2 Posts: 24,579
    verb wrote: »
    you just need to play something it does not need to be loud. I have used inter-station static noise on my tuner while I'm at work.
  • Andohaspolk
    Check out the re-recorded versions of queensrych on Apple Music, thank me later. They are awesome new renditions performed by them.
  • verb
    verb Posts: 10,176
    Will do! Thanks!
    audioluvr Posts: 5,437
    verb wrote: »
    I just played FM radio through mine 24/7 at very low volume. After about a week they are good to go
    F1nut Posts: 49,802
    Just play your speakers as normal. After 48 hours of play the tweeters are as good as they will ever be.
