New Polk HTS Subwoofers
  • WLDockWLDock Posts: 2,208
    edited September 2017
    The plastic base is for sure a matter of personal taste. Overall I think they hit their target design goals of making them look just like the rest of the line and adding in the power port. To do away with plastic would required something expensive like aluminum, hardwood, etc...not going to happen at the given price point. The older Rel T series comes to mind. Much more expensive entry sub. They used a PR some no need for a port.
    Still, not bad looking when looking around at others with a plastic base. As far as spikes...I guess not a part of the design goals. I'm sure they could have come up with a cheap plastic spike design at the very least....I'm seen it many times on other speakers. Still, if one wanted them on the towers...a handy person could add them to the feet...or better yet get a second set to work with. Drill a hole and get something like these to work.
    http://www.ebay.com/itm/Black-Speaker-Spike-Stand-Foot-Speaker-Cone-Isolation-Spikes-Set-of-8-/151624825521?hash=item234d8b3ab1:g:ZjcAAOSwBLlVC3cJ
    FAMILY ROOM
    HDTV - Sharp AQUOS LC-70LE600U 70" | AVR/Streamer - Onkyo TX-NR3008 | Amp - Parasound HCA-1203A
    Blu-Ray/Media/Gaming - Sony PS3-320GB / Microsoft Xbox One | Broadcast - Xfinity X1 Platform
    Front Spkrs - Coming...DIY Statement II | Center Spkrs - Coming...DIY Statement II | Rear Spkrs - Artison Portrait LRS
    Sub - DIY Stereo Integrity HT 15 | Sub Amp - Dayton Audio SA1000
    Wire - Audioquest Type 4, BJC Belden 5000 | HDMI - BJC Belden | Power Cables - Pangea | Surge - Monster
  • @mrloren we may have to set something up then.
    @F1nut, Jesse I will look into that for you.
  • mrlorenmrloren Posts: 1,530
    @KenCustomerService sure thing. I am busy all this weekend. Just PM me when is good for you. I'll give it a test for a week.
    Family Room:
    Samsung UN60H,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk T15
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • Which would be better. 1 SVS SB-2000 or (2)Polks new HTS 12 subwoofer ? Tempted !
  • @F1nut, I finally found out, the HTS does not have the capability to install spikes in them.
  • Mikey081057Mikey081057 Posts: 5,560
    VoodooGTS wrote: »
    Try both brands and return 1
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7004 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC | Samsung 50" SUHD TV | Sony PS4 Pro
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node2 | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Bluesound Node | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP2K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's |
  • rooftop59rooftop59 Posts: 4,640
    VoodooGTS wrote: »
    Depends in part on room and application. If you going to run them in true stereo for music, then two is better than one. Especially if its a larger room. However, the SVS will provide stronger output in the 20-30 hz range and more output overall, and take less space. So, unless you are running true stereo for music, I would go with the SVS.
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio Nova Integrated; Bryson BPD-1; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; LG UP870 4K BDP
    Master Bedroom
    Marantz SR-5007; Peachtree Audio NovaPre; Audiosource Amp Two, PSB Imagine B, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, Squeezebox Touch
  • rpf65rpf65 Posts: 1,785
    VoodooGTS wrote: »
    Have to go with the single SVS.
    I think the bigger amp in the SVS would be stressed less, and I really don't care for the looks of the signature series sub.
  • Rich502Rich502 Posts: 95
    VoodooGTS wrote: »
    A sealed box sub versus two ported subs? Even though the svs is more powerful the output of two ported subs would probably be greater. Why not compare to the PB2000 to two HTS12?
  • Thanks for the input everyone. Mainly use for movies. My current set up is with a SVS PB2000. Sounds great but I was always curious on a dual ported sub set up. Really love how the new HTS12 subs look!
    Wish Polk had a hassle free subwoofer to test the subs.
  • MarflyMarfly Posts: 60
    edited October 2017
    I wouldn't mind a test drive with my TL2 Black Stones. Any feedback on how the HTS 10 would fair in a 2.1 setup with these?
  • EndersShadowEndersShadow Posts: 16,086
    Not that big a deal IMHO. Just grab something like this from lowes, cut it in two, layer the pieces up, paint it black and install spikes on it.
    Or just buy a amp stand as the dimensions should be somewhat similar......
    True, or if you really want spikes just take the money and buy a sub that can accept spikes ;-)
    HT Rig:
    Master Bedroom
  • mikeyb128mikeyb128 Posts: 2,750
    Forget the spikes and put it on an Auralic subdude.
    2 channel:
    Theater:
    mikeyb128 wrote: »
    Decoupling works. Maybe even better than coupling in some cases. No spikes is not the end of the world when dealing with subs.
    FAMILY ROOM
    mikeyb128 wrote: »
    Meant auralex subdude. Looks like my phone learnt Auralic as in the Aries. Haha... so smart but soo dumb.
    2 channel:
    Theater:
  • Anyone had a chance to try the new HTS subs yet? Says its been available from the Polk site for a couple of weeks now.
  • Recently purchased Polk mini, but subwoofer is not sync with soundbar. Please help me how to fix it
  • suresh wrote: »
    Polk MagniFi Mini? If so - instructions to sync are in the manual.
    If I remember correctly, you need to press bluetooth and source button together for 3 seconds until the white lights start cycling. Then press the sync button on the sub.
    (Please double-check with the instructions on the manual).
  • @suresh if those instructions do not work, please email me at [email protected]
  • Ctxx24Ctxx24 Posts: 66
    These would look great with my signatures.. Seems they only go down just under 30hertz tho..
  • felipefelipe Posts: 420
    Hey all. Just got a look at these new HTS subs online...like the styling ;). I wonder if anyone here has tried them out yet? According to Ken, he was “blown away” and “ they are above and beyond the PSW series”...which I put my PSW 108 back into service ( had to return the PB1000 for financial reasons :'( ).
    My Setup: Onkyo TX-NR676, Polk Signature S60 Fronts w/ S30 Center and S55 Rears and S10 Heights, Sony 4K Player, Sony 65”4k TV
    My Folks Setup: Sony STR DH130,Klipsch RP-150M, Sony 3D blue ray player, VIZIO 55" TV.
  • Been playing with them for a while. Big jump in performance from the PSW110 and PSW125 they replace. Am using a pair of the 12s for a home theater setup.
    edited February 17
    I used to own the PSW110 years ago...wasn’t bad at all. How would you characterize the bass of the HTS 12? Why the 12 and not the HTS 10? Do they have good extension?
Howdy, Stranger!
