Polk Signature Series Official Discussion
12122232426
  • djdel002djdel002 Posts: 6
    edited January 25
    Ctxx24 wrote: »
    Who here has s15s on speaker stands and what stand thanks
    Hi Ct,
    Not sure what your budget is but I'm using cheap Sanus stands. They look cheap up close, but ok for the price. $50
    I will probably upgrade to better ones at one point but for now they're ok.
    IF you can spend more there are much better options also depending on the height you want. Mine are 31".
    Also I use Bluetack to keep them in place . I wouldn't even consider not using Bluetack.
    https://www.amazon.com/gp/product/B00006JQ5O/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B001FGLX72/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
  • Ctxx24Ctxx24 Posts: 40
    djdel002 wrote: »
    Ctxx24 wrote: »
    Hi Ct,
    They say the top plate is only 5x5 that seems pretty small.. Price is ok and height is good tho..
  • halohalo Posts: 3,953
    Ctxx24 wrote: »
    I used my S15s with the TransDeco Speaker Stands, 32-Inch and they work brilliantly together. I've moved on from the bookies but still have the stands and I'd be willing to let them go as I'll have no use for them when we move.
    halo wrote: »
    Ctxx24 wrote: »
    How much? I would imagine they aren't cheap to ship
    edited January 27
    If anyone is interested in the s55s they are onky 162 each right now on Amazon.. That's cheap!
    Post edited by KennethSwauger on
  • deronb1deronb1 Posts: 4,190
    I would love to get a pair of S55 in here to compare with the Q Acoustic floor standers.
    Not sure if it's a screw up on their end or what..
    What does anyone think of getting some s60s for the front and moving my 55s to the rear?
  • cfrizzcfrizz Posts: 12,888
    Others, have had towers in front and back and seem to like it, try it and see. However, if you don't like it, make sure you have somewhere else where you can hook up the second pair of towers.
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
    I'm really wondering how different they are gs the 55s if it's worth it.. Or if they would need more power.. I don't use a amp
  • Try it and let us know
    I prolly won't be trying it.. My room is only 10x10 with short ceilings.. I'm sure I wouldn't benefit much
  • tonybtonyb Posts: 28,931
    Ctxx24 wrote: »
    in a 10 by 10 room ? overkill....
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    tonyb wrote: »
    Ctxx24 wrote: »
    Exactly why I chose not to get em.. Mine sound great
    Relocated my s10s from str8 overhead to angled at me and think they sound better..
  • D2Lo wrote: »
    @VoodooGTS asked me for a wall mounted shot of the S15 in a PM. I don't have one of those in our archive but I thought I'd share this wall mount shot of a Signature S10.
    I have my front stage polk audio s20's, polk audio s35, and klipsch r-10sw sub. I now have four of the polk audio s10 to place as rear surrounds and side surrounds.
    Can you tell me what mount was used?
    I would like my wall surrounds to have this same clean look with virtually no wall gap.
  • DaveHoDaveHo Posts: 1,794
    Mostly likely hung using the keyhole slot which is integrated into the power port.
    D2Lo wrote: »
    You they have the built in hole.. I used it on my 10s but I wouldn't think about it with 15 or 20s.
    Ctxx24 wrote: »
    Do the S20 have a keyhole mount built into the back? I thought they did not.
    halo wrote: »
    Ctxx24 wrote: »
    Not sure about the 20s don't have then.. They are ridiculously huge..i wouldn't use them for rears.. Mains they would be good
  • mrlorenmrloren Posts: 1,309
    halo wrote: »
    Ctxx24 wrote: »
    no they do not
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S30
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
    Ctxx24 wrote: »
    You they have the built in hole...
    The older I get, the more I ask that question....don't ask me why. :)
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • ClipdatClipdat Posts: 3,116
    Nice looking setup! The only thing that concerns me is no airspace above the Marantz receiver to allow it to vent it's heat.
    Synomenon wrote: »
    The S20s are pretty huge for bookshelf speakers and they look almost comical in the Audioengine DS2 stands I put them on, but the stands point the speakers up towards the listeners while not raising them up so high that they block the TV. Tried a couple of the foam stands from Amazon and the quality / finish of the foam stands were all sub-standard.
    Got Dayens?
  • I was worried about that too so I cut open the back of that nook in the TV stand the Marantz is in so there would be airflow moving over it either through the front or from the back.
    edited February 27
    Nice. Well, usually they require at least a 3-6"+ or so of air space above the top vents, but maybe since it's their slimline series they run cooler.
    As long as you are happy with the temps, then carry on. :)
    Synomenon wrote: »
    Got Dayens?
    Could alway find a way to mount one of these to pull air over it https://www.coolerguys.com/collections/cabinet-cooling
    These are great if you can fit it https://www.amazon.com/dp/B01LW0G46K?ref=emc_b_5_t
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
  • Ctxx24 wrote: »
    D2Lo wrote: »
    Thank you for the information. I now have my brand new 5.1.4 media room set up with Polk S20 Fronts, Polk S35 Center, Polk S10 Surrounds, and Polk V60 in ceiling atmos (x4), and Klipsch RS10W subwoofer, all driven by an Onkyo TX-RX920. The signature series sounds amazing, combined with the V60s. The sound envelop is seamless.
    All that's left to do is replace furniture, carpet, and paint.
    Congrats and Welcome to Club Polk!
Howdy, Stranger!
