Bi Wire Jumpers
Hi all, a question about jumpers. I'm using Audioquest GBC 12awg bananas as the cables for my RTIa9 speakers & want to give this bi wiring a shot. I see that AudioQuest has a Saturn PSC jumper set with spade/banana connectors, but can't find what gauge it is...based on the pics the jumpers seem thick enough. I'm just not sure if the gauge of the jumpers has to exactly match the speaker wire, as long as it's relatively the same thickness? Also, I notice arrows on the jumper sleeves...must those point towards the open top posts I'm connecting to?
Thanks in advance for any help.
Best Answer
  • rpf65
    rpf65 Posts: 2,127
    Answer ✓
    Don't get too hung up on wire gauge.
    Audioquest makes good quality cables. That's aguarble the most important part in cable selection. They aren't going to sell inferior jumpers and risk their reputation. That would kill their profit margin.
    The arrows point in the signal direction. Arrow points away from source.
