New 1C Purchase Questions
13»
  • audioluvraudioluvr Posts: 152
    Last thing was to install spikes bought here:
    https://meniscusaudio.com/product/mirror-image-pts-gold/
    I started by removing the plastic feet on the bottom cap. Then I drilled a 7/32" hole, sprayed a little water in it, added a drop of Guerilla glue, then screwed in the stud. This anchors them in solid. cqqel85fewl3.jpeg
  • F1nutF1nut Posts: 38,793
    Any glue that foams creating air bubbles in it cannot make a good bond. Throw that stuff away and next time try 5 minute epoxy.
    The spikes do look good.
    The expansion actually allows it to penetrate the pores in the wood and fill any gaps in the studs' threads. I've used this stuff on a boat I restored and it is wicked strong. Epoxy would have been a PITA because I needed such a small amount in each hole. I may use epoxy to anchor the spike bases to the cap though. Haven't decided if that's necessary yet.
    I like these spikes because you can tilt the speakers back and unscrew the points, get placement dialed in, then reinstall.
  • pitdogg2pitdogg2 Posts: 8,831
    edited February 12
    On similar speaker bottoms I have just ran a bolt/washer through from inside the cabinet and tightened down good and tight on the same spikes. I buy mine in 1/4" x 20tpi pattern and just buy some new bolts instead of the threaded rod sent with.
    verb wrote: »
    Hey I noticed you put some dynamat on the brace in between the MW's. Never seen that before. Is that recommended?
    I tapped along the cabinet area looking for potential resonance points and found that and in the center of the 4 drivers as questionable. May have been unnecessary but WTH. Can't hurt right??? :#
13»
Howdy, Stranger!
