Monitor 10 in Rosewood
Picked up a nice set of monitor 10 yesterday that are the rosewood finish. These are earlyish versions with the odd old style grille attachment and peerless tweeters, but still the coated cones and two fuses.
One tweeter is bad (tested and taken apart) so I am in need of one. They have the little hole/dimple.
I will recap as well. There is a light grey mortite type material used to gasket the drivers and crossover/connecting cup so I will replace that as well. What do you guys use to replace that usually. I have some of the mortitie stuff.
Citation 1, WOPL 400, Dynaco ST70, Pioneer SA9100, 5580, Marantz 4400
ADS 1590, AR9, Altec Santiago, Apogee Slant 6, KEF 104/2, Tannoy Mayfair, Allison One, Dahlquist M-907, JBL 4313b
Technics SL1015, Denon DP-62L w/103
  • mhardy6647mhardy6647 Posts: 16,113
    :) Nice loudspeakers.
    Morphologically virtual twins (so to speak) to my Monitor Series Model 7As (purchased in 1978) - right down to the "rosewood" vinyl.
    It's pretty hideous, isn't it? :|
    11208642076_3f7f8db8b1_b.jpgPolkmonitor7Asn4900 by Mark Hardy, on Flickr
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
  • verbverb Posts: 828
    Admiring all of your collection. You should open up a museum!
    2CH: Micro Seiki MB14 TT, Rotel 1580 Pre, Marantz CD6006 CDP, Carver TX8 Tuner, Carver TFM35x Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's
  • teekay0007teekay0007 Posts: 1,973
    verb wrote: »
    He threatened to once. The price of admission was going to be that following your visit, you had to take a piece of equipment upon your departure.
    It may well come to that.
    The Polks won't be at the top of the door prize list, though! :)
  • drugolfdrugolf Posts: 21
    Back on point here....
    I am need of one Peerless tweeter if anybody has a spare.
    Also, looking at the crossover, What brand caps have you guys had good results with? I tend to lean towards the 5% Daytons. I see motorhead recommended Sonicaps in another thread. What do you think about just going with an NPE for the 34UF cap? Change the resistors?
  • pitdogg2pitdogg2 Posts: 8,831
    Or two 17uf film caps for the 34uf. Not much sense to put another NPE in there. Polypropylene film caps are much better and will out live the NPE by generations.
  • F1nutF1nut Posts: 38,793
    Sonicap has all the values you need and sound way better than Dayton/Bennic.
    edited February 10
    I concur, FWIW. The Daytons (rebranded Bennics) are good cheap capacitors (far superior to generic NP electrolytics, e.g.), but these loudspeakers do deserve better than the Daytons. :)
    Save the Daytons for the Jensen era Advents, EPI "T/E series" -- stuff like that :|
    What? Install $170 worth of caps into a $200 pair of speakers! Monitor 10's are nice speakers, but they ain't that nice.
    See this is the problem with caps. You've got the Dayton price level, and then typically too big a jump up.
    there's all kind of price points - see www.madisound.com (e.g.) or www.partsconnexion.com
  • DSkipDSkip Posts: 13,909
    Dru I agree. I don't think the 10s are worth that kind of investment though many have. You would hear the difference in caps but you'll never get around the 10s design flaw.
    I love the 10s and would love to have some in the garage but they'll never be a main speaker for me.
    Also, while they may sell for $200 or less, you've got a lot more value in them than that. If you look at it as an investment go cheap. If you look at it as personal enjoyment, spend more. The one area almost every speaker builder cuts costs with is the crossover. Nobody sees it and nobody ever thinks about the impact it has on sound. Many don't even believe it does impact the sound.
    audiothesis.com/
    Speakers: Harbeth: P3ESR, 30.2, SHL5+; Usher: CP-6311, Be-10, T-515; Rosso Fiorentino: Elba, Fiesole, Volterra; Polk: T50, Signature S60, S55, S35, S30, S20, S15, RTA 15tl, Sonner Audio Allegro Unum
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Dayens Ampino, Triode Corporation TRV-88SER, MastersounD: Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, AURALiC Altair, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Are the drivers on these supposed to be gasket sealed when mounted?
    I got a replacement tweeter so all is good. They sound very nice, even before new caps.
    drugolf wrote: »
    Yes
    drugolf wrote: »
    Why not? I'm installing $1500 worth of crossover components into speakers that retailed for $900 and it'll be worth every penny.
    drugolf wrote: »
    Oooooo do tell o'chap
    All in good time.
  • FestYboyFestYboy Posts: 1,367
    Ok, now I'll be the impatient one... Tell us now! :D
  • westmassguywestmassguy Posts: 5,893
    All in good time.
    I got a pint of O negative waiting for ya....Spill
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Now Carrying Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
    edited February 20
    All in good time.
    He is more a AB negative kind of guy.....
    All in good time.
    More like ABnormal...
  • drugolf wrote: »
    Hey Dru,
    Don't mind these guys. They're an easily distracted bunch.
    Armacell is the preferred material for making new gaskets. About $11 for a 30' roll at Home Depot. It worked great on my 10Bs.
    Also, FWIW, I sprang for the Sonicaps in my crossovers and have no regrets. Westmassguy, the go-to expert here, promised me "mo' better bass" with them and he wasn't kidding. I know the M10s sometimes get dismissed as mere party speakers but I like mine just fine.
    Hope all's well with you. Let's catch up some time.
    Michael
Howdy, Stranger!
