Sony ES CDP Mods?
Looking to see what mods are available for my recently purchased C333ES. I know from a bit of research that Power cable, dynamat and op amp section are probably where to start. I have a friend locally who worked in Sony service dept for years and can have him do the work. Where do I find what parts are needed for the op amp section? What brand of components are used? Any other upgrade suggestions?
____________________________________________________________ polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS SVS PB13 Ultra x 2Pass Labs X1, Marantz 7704, Sunfire Signature Cinema Grande 400, ADCOM 7807, Panasonic UB420, Sony SCD-C333ES, EPSON Pro Cinema 6050
    pitdogg2 Posts: 24,481
    Up the capacitance of all caps around the dac.
    Reach out to Steve Sank at talking dog transducer co. He helped me plenty. He also may tell you to forget it on that model as some do not respond as well for the money spent to do it.
  • dpowell
    dpowell Posts: 3,050
    Looks like ModWright had a modification for the C777ES top of the line version of this player. My assumption is that much of the foundation of the player between the 333, 555 and 777 are the same but with added features up the chain which would suggest to me that the 333 should respond positively. Also seeing some references to modifying the 333 online but the player is so old that much of the references I'm finding have links that no longer work.
    edited February 2018
    True on modwright
    Some of the 1bit players didn't respond as well as the ladder dac earlier models.
    Hard to believe that modwright had anything for a carousel player. That is a new one on me.
    I have had many Sony ES players i hot rodded a 508 and my x33es both still going strong. Those lasers in the early models are just bullet proof.
    Gave the 508 to my son 5 yrs ago it is his daily driver.
  • dpowell
    Someone local is selling a hot rodded and recently serviced x33es for just under $600. The more I look at the cost of modding players, it might actually not be as over priced as I originally thought.
  • dpowell
    Just finished dynamatting the exposed interior chassis on this player. Getting to the power plug requires a bit more surgery than I'm comfortable with at the moment. It's buried under the first layer of circuit boards and carousel cover.
    SCompRacer Posts: 8,350
    I had a Modwright Sony ES 999 and then a Sony 9100ES. Also had his SWL 9.0 and SWLP 9.0 pre amps. The SWLP had built in phono and Blue faceplate. Fond memories!
    Them hot rod parts sure add up when modding. ;)
    dpowell wrote: »
    The Sony x33es used all Elna Duorex II caps. Those were the most corrosive caps i have ever had the pleasure of removing. They leaked down the leads and through capillary action got into the copper traces and just ate them gone. The only way to tell they were leaking was to look at the backside of the board for black streaks were it ate the copper trace. If i was to ever buy a x33 i would most definitely remove both top and bottom covers to take a look see at what was going on.
    Buy the way that player cost less than 600.00 new. I bought mine for just shy of 500.00 brand new in the early 1990's 91 or 92 maybe.
    It would be interesting to see what was hot rodded on it.
  • dpowell
    I wonder if the x33es released the same year as the C333ES? Curious if Sony used the same caps.
  • cortico
    cortico Posts: 587
    Did you checked inside for previous updates? I got a old Parasound CD player and the internal DAC was loaded with Nichicon Muse caps, no sure if that was stock...
  • dpowell
    I have a bunch of pics of the internals from last night when I was doing the dynamat. I think it's all stock.
    dpowell wrote: »
    Date is on the back of the unit. My ES knowledge tells me no. X33,X55 and X77 came out way before the X333,X555 and X777 series I'm fairly certain. The first series i remember would be the 500 series then the X## series and then the X### series. I found they had lower than 500 series later but iirc they were Japanese only for a while. Believe it or not the X55 was really the dog in the middle. The X33 and X77 were more highly regarded player's. Sony had some very highly regarded upper ES players that I only dreamed of owning as they were WAY out of my price range even used. They had some high end players that after the very first SACD unit came out that technology washed down to the CD only players that used a heavy brass center puck on the CD and the laser no longer moved the tray with the CD moved across the laser.
    On another note Pioneer had some huge success with their "Stable Platter" machines. Those like the Nakimachi <(spelling) Dragon players are still to this day bringing like new prices on the used market. Many very high end companies used that stable platter transport in their machines.
  • dpowell
    dpowell wrote: »
    November 2000
    DSkip wrote: »
    Anything during that time period using Elna capacitors should probably be replaced ASAP. I've heard from several resources now that the real Elna capacitors were reverse engineered by an imitator and not done well. Somehow they got into the hands of major manufacturers and resulted in massive failure rates - like the RT series from Polk.
    It was not just Elna. Several big names had some counterfeit problems during that time. The Elna Duorex has a well deserved reputation for their corrosive problem. Word from several well regarded sources (to me anyhoot) was they used a fish oil base in the dielectric. The Cerifine uses ceramic and the Silmic uses silk fibers. Both of those are highly regarded electrolytic caps.
  • dpowell
    Dynamat project
  • dpowell
    Closeup of some of the caps
  • cortico
    cortico Posts: 587
    dpowell wrote: »
    It looks decent from here...
    Those all Nichicon? Looks like it from this side.
  • dpowell
    Yep
    Good deal :) those are pretty robust
  • dpowell
    The player sounds fantastic in its stock form. Very natural full sound
