Question: why Hurricane nuts instead of Tee Nuts
    F1nut Posts: 49,798
    Guys, he's not using Mortite. He's using a permanently flexible bedding compound, butyl rubber.
    The problem with that, and I am familiar with butyl rubber, is it is too spongy. While it can make a good gasket it will prevent a solid coupling of the driver basket and the mounting bezel, IMO.
    pitdogg2 Posts: 24,574
    Yes i knew he was not using mortite, but butyl rubber comes many different ways.
    As you are well aware of the backside of dynamat stuff is also a butyl type it sticks pretty good to stuff.
    Anyhoots carry on
  • Rrusse11
    Rrusse11 Posts: 116
    STOP !!!! There is a reason mortite is no longer advocated. At some point you will want to take a driver out. Not only will that be very hard with mortite but it very well may take chunks of the cabinet with it.
    Armacell pipe tape works very well and will allow you to remove the driver if need be EASY.
    If that stuff you're using is anything like mortite do not use it
    Well, I don't know what "mortite" is. But I have used butyl rubber. In my experience it is removable. The answer is to seal the rebate. I'll use some shellac. Couple quick coats will seal the particle board surface. That will prevent the mastic from potentially pulling the board apart. I certainly take your point as to make the driver/speaker serviceable without pulling the substrate apart.
    Lol, this ain't my first rodeo bedding stuff down. AND having to remove it later.
    Just my first expedition with speakers.
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
  • Rrusse11
    Rrusse11 Posts: 116
    Tennma,
    If I could get Imgur to load a pic, I can show you my little pair of Gilbow snips that
    clip off part of the ring. Wiggling/fatiguing the Hnut will work, but by the time you've got one in the vise, I'll have clipped half a dozen. I'm not convinced yet that clipping them at all is needed. I'll have a go tomorrow at setting my PRs, and see if I can get some pics uploaded.
    Verb has the right idea, just more snip than needed.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • Rrusse11
    Rrusse11 Posts: 116
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • TennMan
    TennMan Posts: 1,264
    Rrusse11 wrote: »
    Tennma,
    I think you are probably right that it's not "needed". It's been a few years since I did it so I don't remember for sure. But if you care about the way the h-nut installation looks when you're finished you will be glad you took the time to do it.
  • Rrusse11
    Rrusse11 Posts: 116
    TennMan,
    I can appreciate "how it looks", the only thing is, once done, it can't be seen, soooooo?
    On my PR's it's a deep rebate, and there's not a lot of material thickness left. Several of the screws are already stripped. Mention has been made of spinning the Hnut, ie. it looses it's grip on the particle board and strips.
    I'm wondering whether to leave the full ring and have a little ledge to put a bead of the
    loctite in to help lock the nut in place, provided it's not interfering with the speaker.
    Unlikely by the looks of things.
    My point is, clipping the Hnuts may be much ado about nothing, and there may be an advantage, from a mechanical view, for leaving them complete.
    Pittdogg,
    Alrightey, I had a look at "Mortite", almost undoubtedly a butyl rubber variant. And also the Armacell foam tape. If the point of either/both is get an airtight seal, I'm thinking of the PR press test, my bet is the butyl will give a more positive seal.
    I may well be tempted to seal the entire inside of the cabinet, particle board is notorious for being a hydroscopic material. I realise it has acoustic advantages,
    being relatively "dead", but as a building material it leaves a lot to be desired.
    MDF is better structurally, but I know too many people who've become sensitized to
    the formaldehydes in it. Most of the furniture/cabinetmaking industry never seals the inside of things. Good boatbuilders do.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • Rrusse11
    Rrusse11 Posts: 116
    Dang,
    You guys are posting a lot faster than me! Lol, anyway thanks F1 for the point of having too much of a "cushion". Thin gasket bed is going to be the goal. Minimal
    material and the Hnut should allow me to torque 'em down tight. A good seal on the board should prevent the potential for porosity grabbing, and pulling apart the material for the eventual/inevitable need for disassembly.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
    audioluvr Posts: 5,434
    This is what I used. I cleaned off the old gasket material from the baskets and stuck this on. Crushed down flat like the stock gasket and easy removal later down the road.
  • Rrusse11
    Rrusse11 Posts: 116
    audioluvr,
    Hey, that looks good, just the right size.
    Cheers!
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • JayMX
    JayMX Posts: 435
    edited February 2018
    audioluvr wrote: »
    @audioluvr
    I copied you today as my modded 7’s don’t seal up too great, so I figured what the heck, I’ll give it a shot. Bought a roll for $4.50 at Home Depot. I tested the adhesive to make sure it didn’t screw with the MDF and it’s not strong enough to pull the wood away, so I laid just it in for a test and wow! The tape is perfect size and really easy to handle. H-nuts are on their way, but for now the seal is tons better and kick drum attack is tighter! Thanks for the lead.
    Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (3x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    F1nut Posts: 49,798
    You may have a tight seal, but there's no way the baskets are coupled to mounting bezel. You want a gasket that is paper thin.
  • JayMX
    JayMX Posts: 435
    I agree. This was just a $5 test. The gasket material does compress very well. When the h-nuts arrive I will redo with Armacell on the baskets.
  • RandyCroissant
    I'm with Jesse on this, the MWs should be coupled with the front baffle, I think you will end up with either or both loose screws or deformed screw holes on the MWs
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Rrusse11
    Rrusse11 Posts: 116
    I'll be doing the PR's on my RTA 12s tomorrow. Hnuts and then I'll have a look at the back of the speaker. It's been mentioned that some have removed the old foam gaskets, perhaps the seal as above, there, rather than in the rebate in the cabinet, may ensure a metal to "wood" contact.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • Rrusse11
    Rrusse11 Posts: 116
    Well I've installed about a 150 hurricane nuts now, and feel I'm getting it down, lol.
    My RTA 12s are very much particle board, I stuck with the recommended 13/64" bit.
    I did clip the "wings" around the binding posts, but left the lip, everywhere else. No problems. I'm putting a dab of Titebond on them prior to install, they seat well and I get a good visual on the seat as the glue squeezes out on the exposed flange lip.
    My 2.3s are a better grade of board, closer to MDF, and I went up on the drill size to a
    .208" bit, seated firmly without stripping the philips head of the installation screw.
    I only clipped a couple of the nuts on the tweaters where the internal braces were fouling the back of the nut. Again, the minor intrusion into the hole is of no consequence for mounting the speakers.
    I used some butyl well rolled out to about a 4mm string/boot lace and laid it into the juncture of the speaker flange and the basket, NOT into the cabinet rebate. Now you're just catching the critical corner with the sealant. Scraped the remnants of the tape off the metal bezel, and have a solid metal to board contact. Coupled with the back flange of the hnut, I've got excellent baffle/speaker unification. They sound better, and louder!
    Less is more with the butyl seal, don't overdo it. It doesn't take much if you've got it placed at the critcal juncture. Using the clutch on my battery drill, the drivers torqued in well. Be careful with the plastic tweeter flanges. Now my speakers pass the PR press test.
    Your Mileage WILL Vary
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • JayMX
    JayMX Posts: 435
    So I disassembled my 7's fo install H-Nuts, found that the brown MD rubber window seal does compress down very thin... Definitely thicker than OEM gasket but seemed to work fine for me, so I decided to leave it. Drilled through the gasket, installed the H-Nuts and reassembled. Holy cow they are sealed up tight now. Very pleased with the improvements in low end response.
  • gp4jesus
    gp4jesus Posts: 1,969
    I will file this thread under "next time I open one of my speakers*."
    I followed Jesse w/H-nuts as above*.
    Right now I have more pressing "bought-house-less-than-a-year-ago (honey do)" projects keeping me busy till year's end.
    Rock on & enjoy. Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
