Parasound faceplate replacement
SUbears
Has anyone replaced a faceplate replacement on a Parasound HCA 2200ii, or on any of their HCA amps? Faceplate got wadded up during shipping. Parasound has a replacement faceplate for sale, but unsure about the LED lights and power switch. Is it a basic plug in/out, or a pain in the ****?
The seller was kind of an idiot by not double boxing it and placing it a box 3 times too big and only using air bubbles, pillows...
If you have to ask, it's not a job for you.Political Correctness'.........defined
President of Club Polk -
What else will go wrong because of the harsh treatment and bad packing down the line?
Return it get your money back -
Thanks for the smart **** reply F1, I appreciate it.
If you haven’t realized I haven’t been around all this equipment and how the intricacies of wiring within amps.
Maybe that’s why some audiophiles get that SNOB label. -
It may seem like a harsh reply but if you have to ask, you really shouldn't be messing around inside of electronics with capacitors that store enough energy to ring your bell and then some.
pitdogg2 also raises a very valid point with what other damage the amp suffered that you can't see. And without proper testing equipment, you won't know until you plug it in and potentially ruin a set of speakers if there is a non-visible short somewhere.
It isn't a snob thing. It is a don't let your pride override safety and good judgement thing."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
If it arrived damaged because of the seller's negligence, then you shouldn't have to take matters into your own hands and spend more money to fix problems. File a claim, chargeback, eBay case, etc. Send it back.
Isn’t this site set up for how to, reviews, and other questions? I was simply asking a question, but with every typical Internet forum there always seems to be that easy way out of replying.
Instead of saying well this is how you replace it, or saying that it may be a dangerous and risky job.
How would anyone else’s take that response. If you feel like you’re going to be a smug about it then don’t reply. That’s not helpful.
On another another post I felt really encouraged for about 5 minutes when another member said keep it up, ask more questions. Then quick reply from F1 again trying to make himself feel better by saying NO you’re not getting it. I’m not a electrical engineer for F sake. To possibly learn things about voltage and and wiring through texts in 1 post is nearly impossible...
I’m sure most on this site, this has been their hobby for many yrs. it’s only been 7-8 months for me.
Thanks! -
Hello,
Usually face plates are not very difficult to exchange, most of the time once the top has been removed you can see how the off/on switch is attached to the front. There might be a mounting clip for the LED that easily releases the assembly. It could be a small amount of hot melt glue holds it in place. Both the on/off switch and the LED could unplug from the circuit, making that part easier.
Parasound might be able to give you an idea how hard it might be. The DIY site has a few photos of the inside, but not enough detail to know about the front panel. -
Thank you very much!
You're welcome.
Have you had a chance to test out the amp in order to determine if it's functioning correctly prior to fixing the aestethics?
50 on the volume display still doesn't mean halfway.Political Correctness'.........defined
Jesse can be abrasive, but he is a wealth of knowledge and information, which you can actually extract out of him if you approach him in a calm and respectful manner.
Instead of name calling and personal attacks.
Your choice though.
Post edited by [Deleted User] on -
I completely understand that I probably shouldn’t have called him a smug @#$&..
However, I’ve only ever posted 4 times, and 1/2 of those were responded with the same quick dismissive attitude from the same member. Just because he’s been on the site since 2002, doesn’t give him permission to portray that cocky know-it-all attitude. It’s just better when someone like that says nothing at all.
I do enjoy reading posts on the site. I find most posts helpful and informative.
Thank you! -
Go to your safe space, you'll feel better. Maybe then you'll realize the advice I gave you is spot on.Political Correctness'.........defined
Thank you!
I feel ya @SUbears ! I've been on this forum for a couple a months and yes you must have a thicker skin at the beginning. Hang in there! There is a wealth of knowledge here. Keep it fact based, decipher the "remarks", and you'll be able to glean what you need. And before long, you'll be sharing as well. And you'll be giving it back "remarks" before long!
Most folks on this site have a great sense of humor and the bantering is fun! Heck I even made @F1nut laugh a few times!
I find that searching within CP helps alot. Most of my questions/issues have already been visited many times here. It shows that you're willing to study a bit and research things, the folks here at CP truly appreciate.
I'll be curious as to how yout faceplate replacement goes. The affects on the internals mentioned above is a very good point, you should check those as well.
Keep us posted!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I can see that McDonald’s is your safe place, but I found other members feedback much more useful. Thanks.
Was that too abrasive?
Oh, you're not gonna last long around here are you?
Uh, yeah. Nobody pokes anyone personally. Did you read my post?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Welcome, don’t be offended. It could save you some painPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Hey F1... is the snow starting to melt up your way, or are those flakes still falling?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Send the amp back, get your money back and buy a different one. Damaged gear isn't worth messing with.____________________________________________________________ polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS SVS PB13 Ultra x 2Pass Labs X1, Marantz 7704, Sunfire Signature Cinema Grande 400, ADCOM 7807, Panasonic UB420, Sony SCD-C333ES, EPSON Pro Cinema 6050
This is the best advise. Damaging a faceplate takes some blunt force, no telling what other issues lurk within. Send it back and get a different amp.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
