Are SW120's and SW121's interchangeable?
verb
I've been in the middle of my 1C upgrade path and as a lot of you folks, looking for spare parts. Lot's of SW121's out there, but the SW120's are not as abundant. My 120's are fine, as I only had to do a minor surround repair. Thanks @f1nut and @westmassguy for your tutelage on that!
I've learned that the SW120's have at least 2 different variants. One with a thicker "cone" and one with a thin cone plus a weight on the Styrofoam piece on the backside.
Borrowed from @Mrbubbles2 post (2011) SW120 circa 1983. Thin cone plus weight:
I also have the same ones with the thinner cone and weight circa 1987:
Can I swap out the 120's with 121's if needed? Obvious question are the sonic differences significant? Newbie slack in affect here
Or should I stay on course (wait for 120's) within the rabbit hole or am I veering into a ditch by snagging a set of 121's?
Please advise.
Please advise.
The 120 and 121 have different weights and therefore different specs, so not a good idea to swap one for the other.Political Correctness'.........defined
President of Club Polk -
Thanks Father. I will stay the course. Patience grasshopper.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I have many spare passive's which do you want sw120 or sw121
SW120! Would like 2 of em!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Looks like i have 3 pair of sw 121
Hoarder!
You do not even want to know the MW drivers I'm sitting on...
Sw120 has the bolt weight correct? Two of mine are dynamatted so i cannot see number. I'll take some out of my active speakers see if they have the bolt. These i put second skin on so if they have the bolt weight we'll go from there.
Looks like i have 3 pair of sw 121Hoarder!
Don't be jelly...that's all he got out of the divorce2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »
The truth hurts but Ron hit on the head -
Fixed -
Nope...
Careful Ron will give ya a good flexin -
Yup mine has the weight. There is a SW120 version w/o the weight too.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
After work tomorrow I'll take apart the SDA1 signatures I'm real sure i put SW 120's in it. -
Yeah work tomorrow. Ugh. Thanks @pitdogg2 !Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I had a bunch of 120's but when I tested them, there was no continuity, so I threw them out.
Thanks @pitdogg2 but those are 121's.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yes i know just putting it out there for others.
All of mine are sw121. The pair in my SDA1Signatures are as well.
Thanks for checking!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
