Transfer of sound from tweeter to soundbar.
I purchased a DSB1 soundbar and sub woofer and tweeters thru Dish. Sound moves from tweeters back to soundbar causing a decreased in sound level. Contacted Polk customer service and they had me to reset the speakers to the soundbar. Didn't correct the problem. Using optical cables - what could be the problem - still under warranty - purchased in Dec 2017 - what should I do.
  • stangman67
    stangman67 Posts: 2,185
    Come again? Your post is very confusing. When you say “moving from tweeters back to soundabr” what exactly do you mean?
  • mdaudioguy
    mdaudioguy Posts: 5,165
    I think the OP might be inaccurately referring to the smaller DSB3 rear surround speakers as "tweeters." I *think* that the D in the model number indicates a model sold only through Dish Home Services. The OP should contact the Dish installers to come back and correct the problem.
  • gwells, what was your solution?
    I have the same problem. Got from Dish, Soundbar DSB1, Base DSB2, Rear DSB3.
    When I follow the instructions I can get the base to connect. Then when I finally get the rear DSB3 to connect the base disconnects. I have not been successful getting both DSB2 and DSB3 to connect with the soundbar together. These connect either one or the other but not both.
    thanks, Ron at rdowdasat@gmail.com
