Help me design my new man cave!
124»
    nooshinjohn Posts: 25,094
    edited January 2018
    Not true... the reason Father McKenzie darns (fixes the holes) in his socks with nobody there is to make certain nobody sees their true color.
    Father McKenzie, writing the words
    Of a sermon that no one will hear
    No one comes near
    Look at him working, darning his socks
    In the night when there's nobody there
    What does he care
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Upstatemax wrote: »
    mdaudioguy wrote: »
    nspindel wrote: »
    mdaudioguy wrote: »
    I'm sending them all back! :p
    I'll take it all back!!!
    Too late. I painted everything orange and black.
    How did you find black paint?!
    It's not a true black. Looks more like a very deep Slate Grey.
    Try squinting.
    txcoastal1 Posts: 13,132
    Where's toolfan
  • soundfreak1
    soundfreak1 Posts: 3,386
    nspindel wrote: »
    Anyone know how well the engineered hardwood would do acoustically? If it were laid down as a floating floor as opposed to gluing it down, would it matter? Probably overthinking things, but I only get to do this once!
    This is just the outer edge of the rabbit hole......the floor! Oh crap.... the floor! LOL you are in big trouble now!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    pitdogg2 Posts: 24,556
    Well usually there is a soft barrier between it and the old floor. For all intents and purposes it should be no different that any other hard floor.
  • nspindel
    nspindel Posts: 5,343
    I ended up going with solid 3/4". There's an acoustic underlayment to try and keep things quiet. From what I can tell, it doesn't do a whole lot. Things are just about done upstairs, I'm going to start bringing stuff back from storage this weekend. Still need to build the wet bar, we'll do that at the same time we get a bathroom finished downstairs. But meanwhile it's time to move in!
  • nspindel
    I brought some stuff home from storage tonight. 1 truck load, just enough to get loud. But then a bottle of bourbon got in the way.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Must have been some damn good bourbon! :o
    Or, could it be.... The Yankees in spring training? :)
  • nspindel
    That night it was the bourbon. Things got loud real quickly after that. Still really getting set up in there, but doing some traveling soon. I’m definitely going to take some photos soon.
