Show me your TT's !!!
1457910
    Clipdat Posts: 12,589
    Not sure what you mean by "not as purty as most", before I even read your comment I thought to myself "Wow, what a gorgeous table!".
    StevieB wrote: »
    My Traveler with a Denon 103R is not as purty as most but sounds very good and hopefully one day I hope to move up the VPI ladder. Also have an old Dual 505-2 and an 80's Technics linear tracker.
    mhardy6647 Posts: 33,021
    edited February 2018
    In fact, on the strength of that photograph, I'd have to say that it's an Epic record player.
    Thank you, thank you, thank you. It took me all the way 'til now to come up with that.
    On a scale of 1-10, how stoned are you right now?
    I am hypercaffeinated, in point of fact.
    At nearly 6pm? You must've got a late start.
  • FestYboy
    FestYboy Posts: 3,861
    No worries folks, Doc will be here all night.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Nesmith98 wrote: »
    see? :)
    32547188461_abe8ed978c_b.jpgDSC_6964 (2) by Mark Hardy, on Flickr
    There is a GA-212 downstairs... someplace...
    I have a Philips 977 similar to that one. I think i got it at Goodwill for less than $10.00.
    The 977 is several notches up from the 777 shown before. Interestingly, in the initial lineup of those tts, the 877 was the top. The 977, with the digital display of platter speed (vs. just an LED "graph") came along subsequently.
  • dr1978
    dr1978 Posts: 424
    halo wrote: »
    Technics SL-Q3 w/ Shure M95ED
    Bottlehead Reduction Phono pre with Integration upgrade (Amperex white PQ 6922 tubes) & Mahogany base
    Is that the "definitive version" of Fragile that just came out? One of my favorite albums ever and the new version is packaged perfectly and sounds great.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
  • verb
    verb Posts: 10,176
    afterburnt wrote: »
    Nice! What is that? Looks like you could play a 6ft diameter record on that thing!
    And some tether ball!
    Tony M Posts: 11,013
    Clipdat wrote: »
    I've never used a record clamp/weight of any kind.
    I think they work to better the sound. I have experience with them.
    Now if you listen to heavy metal, there's no use, I don't think.
    Maybe I'm wrong.
    Will a heavy metal or heavy rock fan tell me if the clamps or weights make the music sound better?
  • motorstereo
    motorstereo Posts: 2,049
    Clamps no doubt help vinyl playback. On the rare occasion I'll spin a record it's part of the routine I go through; brush the record, clean the stylus and clamp the record. If you use a loudness button or a sub at a fairly loud volume I've found that spiking the subs and speakers is very important to keep the feedback away from the needle.
  • verb
    verb Posts: 10,176
    This looks minty. No cartridge. Deal?
  • verb
    verb Posts: 10,176
    Another pic.
    The problem is that cartridge choices are very limited.
    That's why it's forty smackers.
    I paid $7 for my TX-2 (as mentioned earlier) with a broken stylus... so I'd say $40 was a tad steep. Not outrageous by any means, but I couldn't see paying much more for a swingin' arm b&o like that one (looks like an RX-2?).
    It may well need a belt -- belts are available for it (someplace).
    Here're your cartridge opportunities:
    https://www.sound-smith.com/bo-cartridges
  • verb
    verb Posts: 10,176
    Yep. Haven't even hooked my Micro-Seiki yet! Help pull me out of the rabbit hole!
    Pretty sure it's an RX-2 (borrowed image).
    Here're your cartridge options:
    https://www.sound-smith.com/lookup/bo-cartridges/108
  • verb
    verb Posts: 10,176
    Enabler! :smiley: Thanks!
    verb wrote: »
    afterburnt wrote: »
    That tt, by the way, is a Fairchild 750. One of the finest turntables made. Ever.
  • ken brydson
    ken brydson Posts: 8,647
    afterburnt wrote: »
    And you can hang your clothes to dry as well...
  • verb
    verb Posts: 10,176
    verb wrote: »
    afterburnt wrote: »
    I see why they call Doc. As in PHD, I presume. So what's up with that tonearm? It seems like it would be very hard to control dynamically. Counterweight seems insufficient. Is that for real?
    Yes, a PhD -- otherwise I'd own nicer hifi stuff ;)
    It's probably real -- tracking error would be (could be) quite low.
    The sufficiency of the counterweight depends on its mass. I am guessing the whole arm/cartridge system is appropriate for a low compliance MC cartridge.
    http://twogoodears.blogspot.com/2017/02/analog-machism.html
  • verb
    verb Posts: 10,176
    You are an encyclopedia! Impressive. BTW BS Aero, MS Mech :smiley: yes you're credentials are longer than mine!
  • verb
    verb Posts: 10,176
    Whoa that looks cool!
  • verb
    verb Posts: 10,176
    A unique concept. Making a comeback?
  • afterburnt
    afterburnt Posts: 7,892
    verb wrote: »
    afterburnt wrote: »
    jk, that's for polo not music
  • verb
    verb Posts: 10,176
    nbrowser wrote: »
    This is cool and kinda looks like a turntable...I'd rock it!
    Circa mid 1970s
    nooshinjohn Posts: 25,089
    On heavy rock, where there is some actual talent involved, ring clamps and center weights do make a difference.
    Nothing helps KISS sound good, but they are fun to listen to anyway. :p
  • BlueFox
    BlueFox Posts: 15,251
    Every time I see this thread title my mind adds an ‘i’ into it. And I am disappointed every time. :)
