Looking for tweeters for my sda srs speakers
I just purchased a set of these humongous speakers and was told that I should upgrade the tweeters. Any suggestions
Best Answers
Answers
  • Now I come to find out that the person I purchased them from doesn’t have the interconnect cable for it and need the one with a pin and blade...I called Polk and they don’t carry that anymore... any suggestions
  • michaeljhsda2
    michaeljhsda2 Posts: 2,165
    edited January 2018
    Can you post a pic of the front of the speakers? Need to see what type of tweeters you have. Since it's a pin/blade interconnect socket, they are at least SDA SRS 1.2's (can be upgraded to the TL) and if they have SL3000 tweeters you have SDA SRS 1.2TL's.
    SDA SRS 1.2TL's
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 2B TL's w/RD0198-1's
    Yaqin MC-30L integrated tube amp
  • Forgot to address your question... sometimes you can find a used one for sale on Ebay and in this forum. Some people have removed the pin/blade socket and replaced it with a SpeakOn connector.
    SDA SRS 1.2TL's
  • Moose68Bash
    Moose68Bash Posts: 3,842
    Time for a Dreadnought! :)
    Welcome to the Forum and the Rabbit Hole!
    What gear are you running with your "humongous" vintage Polks?
    audioluvr Posts: 5,420
    edited January 2018
    You could use a single 12 ga. Speaker wire with banana plugs on each end connected to the IC pins temporarily.
  • audioluvr wrote: »
    True, I forgot about that idea. Just trim off the petals that surround the pin on the banana plug.
    SDA SRS 1.2TL's
  • I too am looking to replace my SL2000 tweeters. Who is CS, I’d like to contact them.
    Robert
    pitdogg2 Posts: 24,480
    edited October 2018
    knish71 wrote: »
    Robert
    Polk customer service
    The replacement tweeter is RD-0194
    Call: 1.800.377.POLK (7655) Option 1
  • Thank you very much
    Robert
