New PC
I added a computer to my rig today .
An HP Slice Elite...
It's a tiny lil desktop with a 256GB SSD and Win 10 Pro.
Plugged it into my AVR via HDMI and installed my Roon Core on it.
It controls the Bluesound Node 2.
It came with an Optical Drive as a promo that just sits underneath it and connects via I think it's a USB-C
Totally quiet as it has no moving parts (I guess it will make noise if you are using the ODD) and it boots much quicker than a traditional desktop and takes up very little space. (6.5" x 6.5" x 3")
Got some sper a mentin to do to get as much multimedia stuff outta dis pup....
Garage | Polk Monitor 5B's
  • Conradicles
    Conradicles Posts: 6,010
    Nice. How much $?
  • Mikey081057
    Mikey081057 Posts: 7,127
    $789...There are cheaper brands than HP out there with similar specs for a little less but after the dell desktop I am back to HP.
    Always had great luck with HP and their support is great.
  • Mikey081057
    Upper left by the PS4
  • Mikey081057
    Solid State HD's definitely worth the extra $$$. They will come down in price and be alot more affordable.
    Big advantage to audio is speed and quiet.
