MIT Z-Duplex Wiring Question
nspindel
in Electronics
Can't seem to find my instructions, and can't find online either. Green is ground, brown is hot, blue is neutral, correct?
Hmmm, I've got the 20amp, and the wires are not black and white. They're blue and brown, in addition to green which had better be ground.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Actually, just did a bit of googling and turns out that brown = hot and blue = neutral are international color codes. So there you have it!Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Brown will load or hot
Blue will be neutral or white
Green is always green
Ground
