Polk Signature Series Official Discussion
1212224262730
  • Ctxx24
    Ctxx24 Posts: 66
    It's very legit and all mf warranty are honored.. Bought from them a few times
  • dr1978
    dr1978 Posts: 424
    That's where I picked up my receiver, no issues so far. I was planning on standing pat for a while, but if this deal is still around in a couple months when my finances loosen up some I might have to pull the trigger. Under $500 for a pair, delivered? Wow
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
  • Well I am in Canada and paid 798 Canadian for my pair of S60 and free delivery from an electronics store here in Canada. I think for the price you can get these speakers for it is a no brainer. Polk has done a great job with these speakers as far as I am concerned
  • Ctxx24
    Ctxx24 Posts: 66
    Who here has s15s on speaker stands and what stand thanks
  • djdel002
    djdel002 Posts: 6
    edited January 2018
    Ctxx24 wrote: »
    Hi Ct,
    Not sure what your budget is but I'm using cheap Sanus stands. They look cheap up close, but ok for the price. $50
    I will probably upgrade to better ones at one point but for now they're ok.
    IF you can spend more there are much better options also depending on the height you want. Mine are 31".
    Also I use Bluetack to keep them in place . I wouldn't even consider not using Bluetack.
    https://www.amazon.com/gp/product/B00006JQ5O/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B001FGLX72/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
  • Ctxx24
    Ctxx24 Posts: 66
    djdel002 wrote: »
    Ctxx24 wrote: »
    Hi Ct,
    They say the top plate is only 5x5 that seems pretty small.. Price is ok and height is good tho..
  • halo
    halo Posts: 5,616
    Ctxx24 wrote: »
    I used my S15s with the TransDeco Speaker Stands, 32-Inch and they work brilliantly together. I've moved on from the bookies but still have the stands and I'd be willing to let them go as I'll have no use for them when we move.
  • Ctxx24
    Ctxx24 Posts: 66
    halo wrote: »
    Ctxx24 wrote: »
    How much? I would imagine they aren't cheap to ship
  • Ctxx24
    Ctxx24 Posts: 66
    edited January 2018
    If anyone is interested in the s55s they are onky 162 each right now on Amazon.. That's cheap!
  • deronb1
    deronb1 Posts: 5,021
    I would love to get a pair of S55 in here to compare with the Q Acoustic floor standers.
  • Ctxx24
    Ctxx24 Posts: 66
    Not sure if it's a screw up on their end or what..
  • Ctxx24
    Ctxx24 Posts: 66
    What does anyone think of getting some s60s for the front and moving my 55s to the rear?
  • cfrizz
    cfrizz Posts: 13,415
    Others, have had towers in front and back and seem to like it, try it and see. However, if you don't like it, make sure you have somewhere else where you can hook up the second pair of towers.
  • Ctxx24
    Ctxx24 Posts: 66
    I'm really wondering how different they are gs the 55s if it's worth it.. Or if they would need more power.. I don't use a amp
  • Try it and let us know
  • Ctxx24
    Ctxx24 Posts: 66
    I prolly won't be trying it.. My room is only 10x10 with short ceilings.. I'm sure I wouldn't benefit much
    tonyb Posts: 32,902
    Ctxx24 wrote: »
    in a 10 by 10 room ? overkill....
  • Ctxx24
    Ctxx24 Posts: 66
    tonyb wrote: »
    Ctxx24 wrote: »
    Exactly why I chose not to get em.. Mine sound great
  • Ctxx24
    Ctxx24 Posts: 66
    Relocated my s10s from str8 overhead to angled at me and think they sound better..
  • D2Lo wrote: »
    @VoodooGTS asked me for a wall mounted shot of the S15 in a PM. I don't have one of those in our archive but I thought I'd share this wall mount shot of a Signature S10.
    I have my front stage polk audio s20's, polk audio s35, and klipsch r-10sw sub. I now have four of the polk audio s10 to place as rear surrounds and side surrounds.
    Can you tell me what mount was used?
    I would like my wall surrounds to have this same clean look with virtually no wall gap.
  • DaveHo
    DaveHo Posts: 3,471
    Mostly likely hung using the keyhole slot which is integrated into the power port.
  • Ctxx24
    Ctxx24 Posts: 66
    D2Lo wrote: »
    You they have the built in hole.. I used it on my 10s but I wouldn't think about it with 15 or 20s.
  • halo
    halo Posts: 5,616
    Ctxx24 wrote: »
    Do the S20 have a keyhole mount built into the back? I thought they did not.
  • Ctxx24
    Ctxx24 Posts: 66
    halo wrote: »
    Ctxx24 wrote: »
    Not sure about the 20s don't have then.. They are ridiculously huge..i wouldn't use them for rears.. Mains they would be good
  • mrloren
    mrloren Posts: 2,454
    halo wrote: »
    Ctxx24 wrote: »
    no they do not
    tonyb Posts: 32,902
    Ctxx24 wrote: »
    You they have the built in hole...
    The older I get, the more I ask that question....don't ask me why. :)
    Clipdat Posts: 12,557
    Nice looking setup! The only thing that concerns me is no airspace above the Marantz receiver to allow it to vent it's heat.
    Synomenon wrote: »
    The S20s are pretty huge for bookshelf speakers and they look almost comical in the Audioengine DS2 stands I put them on, but the stands point the speakers up towards the listeners while not raising them up so high that they block the TV. Tried a couple of the foam stands from Amazon and the quality / finish of the foam stands were all sub-standard.
  • I was worried about that too so I cut open the back of that nook in the TV stand the Marantz is in so there would be airflow moving over it either through the front or from the back.
    edited February 2018
    Nice. Well, usually they require at least a 3-6"+ or so of air space above the top vents, but maybe since it's their slimline series they run cooler.
    As long as you are happy with the temps, then carry on. :)
    Synomenon wrote: »
