Show me your TT's !!!
2456710
    Clipdat Posts: 12,560
    edited January 2018
    It was on the old forum format before it switched over to vanilla, so I don't think it gets indexed in the search results.
    verb wrote: »
    Cool. I must have searched hard enough ....
    Great dust cover!
    tratliff wrote: »
    VPI Prime with SoundSmith Zephyr MIMC Cart. Pre is a Parasound JC3. Dust cover is a StereoSquare.
    Tony M Posts: 11,009
    NICE!!!
  • muncybob
    muncybob Posts: 2,963
    I asked for a cork TT mat for Xmas and got one....man, talk about static. Had to take it off and go back to the stock rubber mat. I hope in the humid summer I can try it again. Anybody else experience this with cork?
    Yep, my name really is Bob.
    Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, modded Polk SDA 2B, Rythmik L12 sub.
    mhardy6647 Posts: 32,926
    No, actually (and now that you mention it, and FWIW) -- and it's dry here in the wintertime.
    nooshinjohn Posts: 25,034
    I have a carbon fiber mat on my TriangleArt, and love it.
    That should be antistatic. :|
  • MrBuhl
    MrBuhl Posts: 2,419
    I have a home brew mat that I like a lot, basically its composed of a very thin cork sheet (a few sheets of paper thick) glued and compressed onto a thin piece of leather, (unfinished side up), not too ugly and works like a charm. A bit finicky to make correctly but worth it.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • verb
    verb Posts: 10,176
    Of course it's carbon fiber. Direct from NASA I presume ...:)
  • verb
    verb Posts: 10,176
    Here's one I mentioned and a few more pics I found of my Technics SL1400Mk2.
  • verb
    verb Posts: 10,176
    Toolfan66 wrote: »
    Nice !!! Is that a VPI ???
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    Nice !!!
  • verb
    verb Posts: 10,176
    agfrost wrote: »
    My main table (Micro Seiki DQ-50):
    Beautiful TT !!! I like what looks to be all metal tonearm assembly.
    So I was reading some of the Japan market Micro Seiki's were designed for only 100v. Some run a AC converter. Have you had any issues? Is your's designed for 100v?
    tonyb Posts: 32,902
    Saw the thread title and was just wondering if I can buy an "I" for a 50. Be worth it dontcha think.
    Nice TT's gents, keep 'em rolling.
  • vmaxer
    vmaxer Posts: 5,116
    verb wrote: »
    agfrost wrote: »
    I have a DD40, love it.
    Although I do need to get it out and hooked up agay.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • halo
    halo Posts: 5,616
    tonyb wrote: »
    On that note....
    https://youtu.be/HgU_D1-onK0
  • verb
    verb Posts: 10,176
    SCompRacer wrote: »
    Heavy plinth heavy platter Lenco idler drive. Maple wrap, Walnut corner accents. Has tachometer with speed control. Oversize aftermarket stainless bearing, tight tolerance (use light turbine oil). Linear air bearing arm.
    Whoa !!! That is impressive !!! Tachometer? OMG !!!
  • halo
    halo Posts: 5,616
    SCompRacer wrote: »
    BEST vinyl setup I've ever heard. Period.
  • verb
    verb Posts: 10,176
    Just got an education on the speed control and tach. Really cool stuff ...
    http://hifiheaven.net/shop/Phoenix-Engineering-RoadRunner-Tachometer-for-all-Turntables
    SCompRacer Posts: 8,350
    edited January 2018
    verb wrote: »
    Bill retired and shut it down. He was a smart guy, approached TT speed control like nobody had before.
    Thanks for the kind words Victor!
  • agfrost
    agfrost Posts: 2,421
    edited January 2018
    verb wrote: »
    agfrost wrote: »
    That's an interesting question. The DQ-50 is kind of a rare bird; The Micro Seiki it looks identical to is the DD-8, which *is* a 100V motor, I believe.
    Tonearm is some iteration of their vaunted MA-505. It doesn't have the "on the fly" VTA adjusting that some of the standalone MA-505s do, but I'm happy with it.
    Anyway, mine's fine directly plugged into the wall, so no worries for me.
    Jay
  • agfrost
    SCompRacer wrote: »
    Looks like you're running a thousandth of an RPM too fast Rich. Better give that TT to me.
    Jay
  • steveinaz
    steveinaz Posts: 19,521
    edited January 2018
    I love looking at turntables. I was a HUGE fan of linear tracking, and owned 2 different brands of linear tables. IIRC, Yamaha PX-3 and a Pioneer PL1000?? Both very smooth and very quiet turntables. Wish I still had the PX-3.
    Viking64 Posts: 6,646
    steveinaz wrote: »
    Me too, but my neck gets sore and I get a headache moving my head in circles after about an hour or so. :*
    pitdogg2 Posts: 24,478
    scubalab wrote: »
    That table sold for 4000.00 new not too many years back. They were a limited run but WOW that is quite the premium he is looking for.
  • Dawgfish
    Dawgfish Posts: 2,554
    Newest addition, Sony PS-X60 with Audio Technica AT20ss cart
