This should be fun!!!
Just cant leave well enough alone, can you . Gotta put that special "Larry Touch" on everything lol"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
New downspouts?
Speaker stands???"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Uber soundbar?
Speaker stands???
Yep, speaker stands for my LSiM 703’s..
1/2 inch aluminum plate, and 2” x 4” x 1/4 wall aluminum tube. My plan is to have adjustable spikes, and a plug on the bottom to fill it with sand or lead shot..
The top plate is the exact profile of the 703 but it is a 1/4 inch bigger all around. They will be 23-24 inches tall with the spikes..
we have different ideas of what constitutes "fun".
nice job so far.HT SYSTEM-
lsi 9's -
Nice start!
How about a shaft to hide and channel the wire thru?Most people just listen to music and watch movies. I EXPERIENCE them. -
Speaker stands???
Sweet.
Are you going to run some beautiful TIG welds on them to hold them together?"Make a man a fire and he'll be warm for a day. Light
@Toolfan66 you're a sick, sick man.
Where's the hole for the Alexa device to fit in it?
Brian going to get some TIG duty on these?
Finally stands that have a large top plate to match the 703's size! Fantastic!The top plate is the exact profile of the 703 but it is a 1/4 inch bigger all around. They will be 23-24 inches tall with the spikes..
Are you going to fill with sand or shot? Very nice design skills you have. Are you going to polish the aluminum? Good luck. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
No I will do the welding, Brian will do some machining when, and if we can squeeze in the time, we are the busiest we have ever been the last few months, we can’t keep up with demand..Are you going to fill with sand or shot? Very nice design skills you have. Are you going to polish the aluminum? Good luck. D
Not sure on sand or shot, will more than likely paint the stands..
nice job so far.
Italians have more fun making shoes out of wet concrete.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
nooshinjohn wrote: »
Yeah well...they last a lifetime, as short as that life becomes.HT SYSTEM-
lsi 9's -
Larry,
Seeing your choice of material begs me to question if you considered the resonance. Aluminum I would think, rings like a bell, especially being hollow. Thoughts ?HT SYSTEM-
lsi 9's -
Larry,
Once filled, especially if with shot, those resonance should no longer exist. -
True in theory, but you also have the metal to metal between the top plates, columns, and bottom plates on the outside. If it isn't as tight as a 40 year old virgin, you still may get some resonance.HT SYSTEM-
lsi 9's -
I was thinking along the same lines as Tony. Maybe some rubber or felt between stands and speakers? Good luck. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
I'm not too worried about resonance as the material is 1/2 inch thick T6 6061 aluminum, they will be pretty stout even without sand or lead shot. I will more than likely still put the little rubber feet on the bottom of the 703's..
We oughta do a minimal profile of the plates to clean up the laser cut. Maybe even a radius????
The Night is Dark and Full of Terrors -
If needed some dynamat extreme under the base and on of the top of the speaker stand. The rubber feet could be mounted to the top of the stand instead of on the speakers also. This should eliminate the chance of any resonance."Make a man a fire and he'll be warm for a day. Light
You could line with card board before loading?.?...just an idea2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Agree. The Magico cabinets are made from 3/8" extruded aluminum and they are pretty darned inert so I imagine the thicker material to be even more so.
As always, looking forward to the finished project, Larry."Some people find it easier to be conceited rather than correct."
