You're not going to believe this!
Drahthaar
Drahthaar Posts: 48
edited March 2018 in Vintage Speakers
I dont't know whether to laugh or cry
  • verb
    verb Posts: 10,176
    Drahthaar wrote: »
    My preference to the modder:
  • oldrocker
    oldrocker Posts: 2,590
    I've seen worse... :s
  • verb
    verb Posts: 10,176
    I saw this on CL advertising original Advent Speakers. Hmmm... Can anyone tell what model this is ??? :)
    https://detroit.craigslist.org/wyn/ele/d/advent-loud-speakers/6458333470.html
  • FestYboy
    FestYboy Posts: 3,861
    Perfect waste of a pair of peerless... I'm with @verb on this one.
    gudnoyez Posts: 8,056
    Looks like the only thing they had handy for a peerless replacement was a single Kraco coaxial found I'm the garage to funny.
  • Dabutcher
    Dabutcher Posts: 2,588
    How much is he asking for the monitor 10’s? Peace. D
    mhardy6647 Posts: 32,926
    edited January 2018
    verb wrote: »
    That's an Original Large Advent (OLA) -- real walnut enclosure, as opposed to the Utility Large Advent.
    http://www.classicspeakerpages.net/library/cizek/advent_loudspeaker/
    verb wrote: »
  • Dabutcher wrote: »
    $50 for the pair
  • delkal
    delkal Posts: 764
    Drahthaar wrote: »
    Dabutcher wrote: »
    $50 for the pair
    For $50 I would buy them, take out the drivers, and put them out of their misery.
  • FestYboy
    That would be a good start for a DIY vintage center channel...
    Where's he located?
    F1nut Posts: 49,708
    verb wrote: »
    gudnoyez wrote: »
    Looks like he modded his car too ...
    Got to be a carpenter.
  • TennMan
    TennMan Posts: 1,261
    edited January 2018
    My guess is a carpenter that builds forms for concrete. :#:p
    Post edited by TennMan on
    Viking64 Posts: 6,646
    Since when have I had a "not going to believe this"?
  • FestYboy
    edited January 2018
    Viking64 wrote: »
    I think what would be more surprising is a "You ARE going to believe this..." from you :p
  • FestYboy wrote: »
    Where's he located?
    Gainesville Florida
  • FestYboy
    Hmm I'll be in Hot Springs, AR this week. I think that's a bit out of the way :|
    F1nut Posts: 49,708
    Drahthaar wrote: »
    FestYboy wrote: »
    Where's he located?
    Gainesville Florida
    Ah, cracker speakers.
    Drahthaar wrote: »
    Gainesville Florida
    Why doesn't this surprise me? :p
  • headrott
    headrott Posts: 5,484
    Worst part about those Monitor 10's is they probably had Peerless tweeters in them. Those Peerless tweeters are probably now in some landfill in Florida.
    xschop Posts: 4,636
    The silk domes were probably past their prime as they do eventually deteriorate being a protein.
    But that choice of replacement is ghetto.
  • soundfreak1
    soundfreak1 Posts: 3,374
    aprazer402 wrote: »
    Fixed it! :Dp95kwgkgjyjs.jpg
    A little paint, what the hell!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Msabot1
    Msabot1 Posts: 2,098
    Drahthaar wrote: »
    Drahthaar wrote: »
    Will that even work???...nawwwww....
  • verb
    verb Posts: 10,176
    aprazer402 wrote: »
    House paint. Plenty to choose from!
    verb wrote: »
    aprazer402 wrote: »
    As long as one isn't dead-set on the elusive black paint, of course.
  • VSAT88
    VSAT88 Posts: 1,226
    He done made him some home made P horns..
  • verb
    verb Posts: 10,176
    His first speaker mod:
