Gutters
We had a LeafGuard rep come out and give us a quote on their gutter system for our house. After 2 hrs and a bit of haggling about best price, it came to $7,800. While it seems like a decent product and the technology sound, I just couldnt pull the trigger on nearly 8k for gutters. Anyone had these or similar installed?
    treitz3 Posts: 18,327
    Run, don't walk.
    Unless you have a 5 story, multiple high pitch and inaccessible home that requires multitudes of scaffolding and OSHA stopping by on a daily basis?
  • verb
    verb Posts: 10,176
    I had the DIY screens on my gutters. Problem is the small stuff gets through and becomes a bigger pain to remove and then clean. I’m back to just cleaning every spring. This year I was lazy and hired a company for 200 bucks to clean them for me.
    78 large will buy a lot of audio equipment !!!
  • deronb1
    deronb1 Posts: 5,021
    treitz3 wrote: »
    Run, don't walk.
    Ha! No, typical 2 story house. About 190 linear feet of gutters, plus downspouts.
  • Emlyn
    Emlyn Posts: 4,372
    That's expensive, but...
    How many linear feet? Is it the entire gutter and downspout system? What material would the gutters be made from?
    My guess is that the price is for a seamless system with integrated guards, installation, and disposal of the old gutters and repair of any damaged boards. May be a fair price for that, but you could get less expensive gutters. But if other properties in your neighborhood have similar systems you may want to go with the high end system.
    When I had my roof replaced a couple years ago, I thought about getting new gutters too but just kept the ones there. They are steel with grates. Work ok. I have some guys come around once a year to clean them out for around $100.
    Run like your nuts were on fire!
  • deronb1
    Emlyn wrote: »
    Yes, all that you described. Hooded system that uses surface tension to guide the wster into the gutter. Read up on it a bit and many said it cant keep up when it rains really hard. Also hard to clean and could be a good haven for bees and other things.
  • ken brydson
    ken brydson Posts: 8,650
    Had them out for a bid. Not impressed. Gutters more than my roof? I think not...
  • deronb1
    Yeah, its just too much money imo. I dont mind paying for quality items that work as promised, but just started to get that "bent over" feeling.
  • DaveHo
    DaveHo Posts: 3,480
    Assuming your existing gutters aren't in need of replacement, $7800 would pay for a lifetime of gutter cleanings if'n you don't want to climb the ladder.
  • scubalab
    scubalab Posts: 3,101
    Wow, either I'm out of touch with current pricing, or that quote is astronomical! We had a local company put seamless gutters on our house - about 160-170 LF total with 5 downspouts, and a leaf guard system that works very well (our lot is heavily wooded and no problems in the 7-8 years they've been up). If I remember correctly, we only paid $1200.
    Plus, I always doubted that 'hooded' system. Water tension would be overwhelmed in heavy rains, and at that point, the gutters might as well not even be there.
    EndersShadow Posts: 17,531
    I can't clean mine out. I gotta keep my mind in it.
  • polrbehr
    polrbehr Posts: 2,826
    When we had our roof replaced about 12 years ago, we called for a few estimates on replacing the gutters at the same time. When I called, I told whoever I spoke to that our house is single story (it is, but that's another *ahem* story), and I wanted a price per linear foot? Isn't that how it's done?
    Anyway, I got prices ranging from $3.75/ft ~ $6/ft for LeafGuard-type gutters ... until I told them we only needed 60' total. Once that fact came out, I never heard back from any of them. So we had the roofing guy bring his own contractor and had them done for $120. Yeah, I pay $50 x 2 for cleaning them every year, but I figure I can't fall off of a ladder I never set foot on, right?
  • gmcman
    gmcman Posts: 1,759
    edited January 2018
    My neighbor had the larger seamless gutters installed, rolled ends, they are designed for leaves etc....also the larger diameter downspouts.
    2 story above ground, about 150' of gutter, plus 4 large downspouts.
    Install price was $750.
    $7800 is criminal by a large margin.
  • deronb1
    gmcman wrote: »
    Wow! Yeah, glad i declined. Whew!
  • shawn474
    shawn474 Posts: 3,047
    edited January 2018
    We had a similar experience; guy came to the door to talk about roof replacement. We were in the market so my wife said why not? After 45 minutes of measuring and discussing and salesmanship, I ask him for the bottom line price wise. It was like a dealership experience.....MSRO he says would be $17k but if we signed up right now it would only be $13k. I told him not so politely to get the &!$) our of my House for wasting my time. He gets on the phone, rings the door bell and says he just talked to his supervisor and got it down to $8.5k. Long story short, we got the roof replaced with new gutters from a local reputable company for $3k.....
    As for the guards, I use the donut yourself guards. I do have to clean them out once a year for the little stuff that gets through, but we live in a heavily wooded lot and I was having to do it weekly over the fall months. Cost like $200 for enough to do the house all the way around
    PS- this is for a house that is less than 1500 square feet....
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • mrbiron
    mrbiron Posts: 5,711
    $7,800...did they include cab fair home after that forking or did they expect you to walk home with shoes in hand?
  • deronb1
    mrbiron wrote: »
    Ha! In hone sales presentation, but offered no lube...
  • maximillian
    maximillian Posts: 2,142
    I had them installed on my house for just over a grand. They are alright. Critters do get in them. They work with rain just fine but ice buildups up worse. Probably won't do it again.
    $7800 is robbery.
  • kharp1
    kharp1 Posts: 3,453
    Interesting thread as I'm starting to contemplate some home improvements, and, working as much as I do I'm starting to lean to paying someone to do the work, which is something I would have never done a few years ago. New gutters and leaf guards are something I'm considering. Had I gotten a quote like $7800 I probably been arrested for assault.
  • lightman1
    lightman1 Posts: 10,776
    kharp1 wrote: »
    You're a serial killer, Kerry. You would invite the salesperson into your home....and then make sure he never left....
    Viking64 Posts: 6,683
    lightman1 wrote: »
    It rubs the lotion on it's skin or else it gets the downspout again.
  • kharp1
    kharp1 Posts: 3,453
    lightman1 wrote: »
    kharp1 wrote: »
    Oh, that goes without saying, but, I still want my gutters done at a fair price. IS THAT TOO FREAKING MUCH TO ASK!!! DON'T TOUCH ME!
  • verb
    verb Posts: 10,176
    Whatever you decide @deronb1 don't hire these guys !!!
  • shawn474
    edited January 2018
    verb wrote: »
    That’s some quality craftsmanship right there; all that weight on the gutters and no sag?!?!?! I wonder what kind of gutter hangers they were using!!!!
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    shawn474 wrote: »
    ....all that weight on the gutters and no sag?!?!?!
    When I hear the phrase "no sag", I think of something else. But then, my mind is always in the....gutter.
  • gmcman
    gmcman Posts: 1,759
    shawn474 wrote: »
    Not the ones Clark had.
    https://youtu.be/kMtBHA783c8
  • warren
    warren Posts: 756
    14 grand for the roof rwo and a half grand for the Leaf Guard gutters. I sleep well..
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • ken brydson
    warren wrote: »
    $6K for my 40 year roof, $7500 for Leafguards, nope...
  • lightman1
    I have nothing to offer! $14.54 and ham sammich.....
    lightman1 wrote: »
    SOLD!
