Reset Polk Magnifi Mini
jaclbe
Hi all,
just teached my TV remote to do the basic operations of the Magnifi remote as well.
Unfortunately, this is not working well. When I turn on the power button my TV goes on and the Polk goes off. Is there a way to reset the Magnifi Mini or at least unlearn a remote?
Best Answer
Thanks all.
Found the solution for my issue in this post: http://forum.polkaudio.com/discussion/176334/clearing-learned-remote-codes-magnifi-mini#latest.
Answers
Hello,
Usually on Polk's soundbars if you place the unit in the standby mode and touch the "learn" button for a couple of seconds it will delete and learned remote codes. If this doesn't let me know.
Regards, Ken -
To me he puts every time automatically after some time the settings of the bass back to zero. How can you get this fixed?
Hello,
Make sure the soundbar is not plugged into a switched AC outlet, the power needs to be constant.
Ken -
KennethSwauger wrote: »Hello,
Regards, Ken
What, where is "learn " button ?
