Another 1C upgrade path
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    Hurricane nuts? Is that like freeballin' in severe weather conditions?
    LOL !!! For those NB's like me to CP and missed out on Larry's Rings, gotta let just em hang out. Dang it's cold !!!
  • verb
    verb Posts: 10,176
    So took a break from bantering on CP and decided to drill out the cabinets and prep for H-nuts. Special thanks to @westmassguy for the proper procedure:
    The only thing I would add is definitely go slow !!! In fact, I just allowed the weight of my cordless drill to do the cutting. Worked great !!!
  • verb
    verb Posts: 10,176
    Sneak peek. Zebrawood panels for the sides. 1/4" thick, just need to cut on my tablesaw to the correct size.
    Ignore all the materials and tools in the background for the home remodel projects now on hiatus in favor of my 1C upgrade !!!
  • TNTsTunes
    TNTsTunes Posts: 751
    verb wrote: »
    Good advice.
    One of these days I'll get around to installing the Larry's rings I have stockpiled. I have 5 pairs of speakers waiting for them. I think I'm short one set of rings for 10" passives, I should have a bunch of extras otherwise.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • verb
    verb Posts: 10,176
    TNTsTunes wrote: »
    verb wrote: »
    Good advice.
    Dibs on your extras !!!
  • verb
    verb Posts: 10,176
    I love Saturdays !!! Rockin Disturbed Immortalized on my 2B's while playing with the 1C upgrade. Finished drilling out the holes for the H-nuts:
  • deronb1
    deronb1 Posts: 5,021
  • verb
    verb Posts: 10,176
    New MW6511 replacements from Polk arrived today !!! Ready for Dynamat Extreme !!!
    Side discussion below on Polk's replacement of the original vintage MW6511:
    http://forum.polkaudio.com/discussion/180073/mw6511-6503-anyone-using-modern-replacements-update#latest
  • verb
    verb Posts: 10,176
    Getting ready to cut the side panels on the table saw.
    Remember measure twice, cut once.
    Viking64 Posts: 6,688
    verb wrote: »
    "I cut it 3 times and it's STILL too short."
    pitdogg2 Posts: 24,578
    Be sure to relieve the rubber surround where the screw goes. If you do not it will pull on the surround and ruin to driver. Sharp razor
  • deronb1
    This!
  • verb
    verb Posts: 10,176
    Thanks @pitdogg2 and @deronb1 !!! Answered questions not yet pondered, or asked. You guys are good !!!
  • verb
    verb Posts: 10,176
    Yeah!!! Dynamat extreme arrived today. And sonic barrier - thanks @westmassguy. Can't wait until the weekend. Work keeps getting in the way of my upgrade path!!!
  • verb
    verb Posts: 10,176
    Dynamat and Sonic Barrier before cutting:
  • verb
    verb Posts: 10,176
    Zebra wood side panels cut to size:
  • RandyCroissant
    Very nice!!
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Manticore
    Manticore Posts: 408
    Yes indeed very nice. That zebra wood should look real sharp as side panels. Things are starting to take shape.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
    audioluvr Posts: 5,437
    Cool looking panels!
  • Manticore
    What type of wood are you going to use for the top & bottom caps?
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • verb
    verb Posts: 10,176
    Manticore wrote: »
    Haven't decided yet.
    • Walnut in natural finish
    • Oak in dark stain
    • Maple in natural finish
    The side panels IMO would tie in nicely to either light or dark endcaps.
  • Manticore
    /\/\/\Agreed./\/\/\ I don't think you could go wrong with either.
    I personally have always liked the look of the lighter woods.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • TNTsTunes
    verb wrote: »
    I would go with the dark colored end caps personally. Walnut with some lighter grain marks would be sweet.
    From the looks of the side panels two appear to have a darker grain pattern and two are seem lighter. If it was me I would personally install the darker ones on the outer facing sides of each speaker and the lighter ones on the inside of each speaker so they face each other.
    I would also install the first and third panels the way the grain is shown above(left to right). The second and forth panels would the be reversed/flipped to match.
    I'm a bit picky/weird about things like that...
    F1nut Posts: 49,801
    Verb,
    Nothing personal and in my opinion. I've seen countless attempts at doing what you are planning and not one of them looks right in the end. The only one I've seen that looks right is a pair of 3.1TL's that were veneered to look like a studio version.
  • TNTsTunes
    Verb,
    I basically agree. If he only did a single strip like the SRS 2's, 1.2's or 3.1's use it would probably look better. That's just my opinion also, your results may vary.
  • verb
    verb Posts: 10,176
    Verb,
    Yep. As you forewarned me before. I’ll let you know how it turns out!!! Thanks as always for your guidance.
  • verb
    verb Posts: 10,176
    TNTsTunes wrote: »
    verb wrote: »
    I’m with you on that. The grain being so pronounced definitely needs to be matched for a good symmetry. Thanks for your suggestions!!!
  • verb
    verb Posts: 10,176
    Manticore wrote: »
    Yep. So many choices. Maybe I’ll let my Honey decide as she thus far has zero interest in this project!!!
  • verb
    verb Posts: 10,176
    TNTsTunes wrote: »
    Verb,
    I thought about the single strip but decided to go full panel instead. My strategy is to ensure the front edge is aligned perfectly with the cabinet as to keep the relationship the same with the grille. I appreciate your feedback!!!
    F1nut Posts: 49,801
    verb wrote: »
    Verb,
    Am I repeating myself........oh God, it's started.
