Charcoal or fire place users
Dabutcher
Found this new @ GW. Fire started in three minutes. They have them on amazon. Works great. Peace D
I have the same igniter. Works great with lump charcoal. I really like it.
Very cool, new ones are not cheap though, about $80.00. Closest thing to a lightsaber!
Curling iron with a surprise.Don't take experimental gene therapies from known eugenicists.
I guess I'm just old school I use matchesMain Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
My pet squirrel usually lights mine !!!!!If you can't hear a difference, don't waste your money. -
One of those charcoal chimneys is like 10 bucks. On sale they get as low as 6 bucks.Expert Moron Extraordinaire
I like the chimneys for starting charcoal fires. Started with a dump find chimney (duh), went through a couple of cheap ones (which worked fine but burned/rusted out quickly). Bought a Weber chimney (which wasn't expensive, either) and it's served well for -- jeez, I'll bet 7 or 8 years now.
We grille outside a lot (including dead of winter).
Chimney full of charcoal, little crumpled up paper underneath. Add flame and 20 minutes later, good to go.
Long time chimney user too. Toys
Chimney user too. I use the outer part of the charcoal bag for the paper and by the time I get to the end of the charcoal all of the bag is used up too.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
