PR Surround Repair
verb
Please see below.
Just starting to de-laminate a bit, but wanted to fix it before re-instlall into my 1C's. Please advise and opine. Thanks !!!
http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path#latest
Some of that bike inner tube adhesive should do the trick. I'd protect the disc somehow to prevent any from getting on it.Political Correctness'.........defined
President of Club Polk -
Thanks @F1nut !!! I seen that mentioned in older posts, but wanted to get confirmation from the guru(s) ...Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I like 2 part epoxy for repairs , it dries fast and is flexible .it would be a smooth repair if you could use one of those cheap plastic clamps to hold it flat , just be careful not to glue the clamp on to it .
If your 2 part epoxy is flexible after curing the hardener has gone bad or you need a different brand of epoxy. It should cure rock hard.Political Correctness'.........defined
