no bass 3.1tl
13»
Answers
  • ps4y2ch0
    its a little fuzzy, but this is the screw in between the inductors which are then covered by the big black caps. its totally closed off and too narrow to fit just the tip even...
  • headrott
    headrott Posts: 5,484
    Maybe a 90 degree phillips screw driver was used to put that screw in? I don't see how else you could do it by what you have shown and described. That would be my guess, is a 90 degree phillips screw driver.
  • ps4y2ch0
    i may just end up sending them to that ebay guy thats the clup polk member and just let them finger it out. or make a yearlong project for myself to learn on
    pitdogg2 Posts: 24,559
    Who ever did that was clueless to say the least. Now you know why you have a problem.
    Westmassguy here may be able to help you. There is a good chance he will not want to reuse those boards for obvious reasons. New boards run 100.00 take that in consideration.
  • headrott
    edited January 2018
    Yeah, @pitdogg2's advice is good for recommending @westmassguy. Not sure if that is who you were referring to in your post @ps4ych0, but he is a trusted member of the forum and an excellent modifier of crossover boards.
    Edit: Make sure you have the resistors replaced with a good resistor. Mills or Duelund are most common and are both excellent for different sound qualities/reasons. Mills are warmer and less detailed, and Duelund (cast) are more neutral and very high detail.
