2B's Más Huevos
  • pitdogg2pitdogg2 Posts: 9,803
    Brian did you spray paint the inside or is that something else you applied? Looks good by the way.
  • pitdogg2 wrote: »
    Thanks, I brushed on 2 coats of cheap paint from Lowe's.
    The Night is Dark and Full of Terrors
    I just may steal that idea next time i have mine apart.
  • You definitely should
  • xschopxschop Posts: 801
    Hey Brian, I guess I should have asked is there even a brace between the midwoofers to measure?
    The repurposed JBL cabs I saw had a thick coat of roofing polymer brushed on the inside.
  • gimpodgimpod Posts: 1,739
    "If you design software that any moron can use only morons will use it." JMO
    Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
    "Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
    "50% Why... That's almost half."
    "I know, I'm sick and need help."
    www.gimpod.com
    "The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
  • xschop wrote: »
    Yea there's a 9.25"x9.25"x.75" brace. I beveled down the top edges for a little extra clearance for rings. I wish I'd done something completely different while they were out. But that ship has sailed...
  • Well I'm closing in on finishing theses things.
    I made a template at work for these deals I'm using to mount the board.1zzut7b3sul8.jpg
    Mounted the 16mh inductors
  • txcoastal1txcoastal1 Posts: 9,602
    Clean
    I like the wire wrap and shrink job you did in the cabinets
  • ken brydsonken brydson Posts: 6,933
    txcoastal1 wrote: »
    Clean
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • Toolfan66Toolfan66 Posts: 13,630
    I like the hardware you're using, and I also like the wire wrap, I want you to share that with me..
    I'm not sure I like the paint in the cabinets, I think if it was textured it would look better, but I'm not sure if the texture would change the sound..
    Looking forward to hearing them, and what your thoughts are when you're done with them..
    This thread proves the moderators no comprende Espanol.
  • deronb1deronb1 Posts: 4,193
    xschop wrote: »
    Huevos are eggs :wink:
  • agfrostagfrost Posts: 2,125
    I'm still looking forward to how the eggs are incorporated--always looking for ways to improve my 2BTL!
    Jay
    SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8
    Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
  • "Huevos" in Mexican Spanish (which is mostly slang) refers to having guts or balls.
    Jay
    Very cool. Reminds me that I've got a full set of Jantzen inductors to put in place of the stockers.
    May I ask how you secured the SDA inductor to the floor? That's the one detail I haven't worked out yet. (Is that a Northcreek inductor?)
    Jay
    I believe could be a Solen. I do not know if Northcreek is making any these days. Price page is gone and inductor page say's "retired2016" at the bottom.
  • They're Northcreek. I bought them off of Larry awhile back.
    I'll take some pics when I get home. Mounting the inductors turned out to be really easy.
  • TNTsTunesTNTsTunes Posts: 754
    edited January 8
    agfrost wrote: »
    Solen makes an air core 16mH 14AWG inductor PN# S1416.0.
    https://solen.ca/products/inductors/standard-inductors-14awg-1-63mm/s1416-0/
    Post edited by TNTsTunes on
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    Interested as well in the way you mounted as well. post up some pictures ;) Yep if I would of read that second picture it says northcreek right on the box lol
  • westmassguywestmassguy Posts: 6,016
    Just make sure the screw or bolt is non-magnetic, either stainless, brass or even aluminum.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Now Carrying Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • MrBuhlMrBuhl Posts: 2,272
    2bTL's eres muy guapo!
    VA 2 Channel ,Dodd 50W Dual Mono EL34 Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, Audioengine B1, MIT AVt3 Speaker & RCA Cables, PS Audio Power Punch power cables
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
    Nice Job
    Den:
    Man Brian those are super nice binding cups great job on all that. :D
    So pretty you may want to run the speakers facing the wall. :)
    Jay
  • nikoniknikonik Posts: 116
    Órale vato! Those are nice ese.
Howdy, Stranger!
