Best method of transporting vinyl records?
halohalo Posts: 3,716
Hello everyone,
For those that have moved and have taken their record collection with them, what are some tips or tricks as to getting them there safely?
Best method of packing them? Packaging them?
And no, I'm not selling them or giving them away before I move. lol.
Thanks in advance!
  • mhardy6647mhardy6647 Posts: 15,620
    FWIW, I just used cardboard boxes, mostly of the Home Despot kind. Fill 'em full.
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
  • nooshinjohnnooshinjohn Posts: 16,774
    The best thing is to let the records transport you. Just darken the room, grab an adult beverage and let the music flow trough you....
    Oh, you meant move them to another location. I get it now. I used a double walled box that was the same dimension as the record themselves and filled the box to capacity so there was no movement or shifting about.
    How many to you have to sell? I mean move... :D B)
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with PS Audio NuWave Phono converter, Walker Precision Motor Drive, ClearAudio Stradivari v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X1 two channel preamplifier Signed by Poppa himself, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-65, Oppo UDP-205 Blu-ray , Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds
  • dromundsdromunds Posts: 6,414
    You can get some wooden LP boxes/crates if you're worried about anything. Depends on how many you have and how you value them. If highly collectable, etc. I've seen guys use LP hardcases. (That's what I'd use for my 1st pressing sealed Wildflowers, etc.) Definitely fill whatever box you use to capacity as stated above so no movement or shifting.
  • halohalo Posts: 3,716
    Thanks for the input folks!
    I don't need anything super indestructible, I just want to make sure the bottom isn't going to fall out of the cardboard box from the weight of the records. The double walled boxes at H.D. sounds like a good idea. I have ~ 70 records now? Some are not in that great of condition. Others are new or limited editions. So I'd like to try and see if I can get them all there safely.
    Dollar for dollar the Home Despot boxes cannot be beaten -- that was feedback from one of my daughter's long-time friends, who has a moving company as kind of a side business (he's a tech guy of some sort). The heavy-duty boxes from HD are.... pretty heavy duty.
  • EmlynEmlyn Posts: 1,941
    These are tough and good enough for long term storage if necessary. I bought some for my last move a few years ago.
    https://www.sleevecityusa.com/ultimate-lp-storage-box-p/3strlpbox.htm
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Parasound A21; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • MrBuhlMrBuhl Posts: 2,039
    Not inexpensive or of the highest quality, but when I came out here to LA I brought about 200 LP's with me, I bought the LP crates from Container Store, the bigger concern is making sure they don't overheat in transit. Plus side is that these have handles, stack and are easy to carry (because of handles)
    VA 2 Channel , McCormack DNA 0.5 (SMc Gold) Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Toobs Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, VPI Nomad Turntable w/Ortofon 2M Bronze, MIT AVt3 Speaker & RCA Cables, Pangea & Signal Cable MP power
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Dodd 50W Dual Mono EL34 Amp
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Bottlehead Foreplay (modded)
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
  • decaldecal Posts: 2,945
    Emlyn wrote: »
    I second this motion. I have about 30 of these I used to transport my LPs to the new house. They are real sturdy.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,127
    edited January 12
    I just moved our record collection using over 50 boxes from U-Haul they were just right, but I got wore out lifting them completely full so I had to take 70% of the records out of each box near the end. Just about killed me. I could use them over for a couple of times.
    "Passion is inversely proportional to the amount of real information available", G. Benfield
  • msgmsg Posts: 3,609
    I also have some of the Sleeve City boxes. Perfect fit. If possible, and you're driving, I'd maybe consider bringing them with you instead of in a moving truck?
    Another idea would be the Container Store's "record crates". They're a little flimsy compared to real milk crates, and they're open, but they'd get the job done, though wouldn't protect against dirt/dust.
    The Sleeve City ones fold like a bankers box. I'm not sure whether they've addressed this, but the version I have is designed incorrectly. If you know how bankers boxes work, and they haven't adjusted the design, you'll see what I mean when you go to fold one.
  • hochpt21hochpt21 Posts: 4,928
    I used something similar to a milk crate, but they were deeper and wider.
    __________________________________________________
    Turntable - Pro-Ject 2.9 Wood/Grado Gold Cartridge
    Phono Stage - PS Audio GCPH
    Preamplifier - Dared SL-2000A
    Amplifier - McCormack DNA 0.5 Deluxe
    Speakers - GoldenEar Triton 2
    7.1 Home Theater
    Denon AVR-X3300W; Rotel RMB-1066; Polk CS350ls, LS90's, FXi3's, RC60i; SVS PC Ultra; BenQ W1070; Elite Screens 120"
    Man Cave
    Turntable - Sony PS-LX410/Grado Green Cartridge
    Phono Stage - Parks Audio Budgie
    CD - Marantz DV4001
    Passive Pre - Luminous Audio Axiom II
    Amplifier - Parasound HCA-1500A
    Speakers - SDA 2A (x-overs etc...); Epos Epic 2; Polk Audio Monitor 70 (my first)
  • Easy RunninEasy Runnin Posts: 372
    12 inch Pizza boxes. Lay enough in to fill the box then tape it em up tight.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • gudnoyezgudnoyez Posts: 5,812
    I would not go all out for transprting them. I would get some cardboard boxes a tad bigger than 12X12, pack them transport them and don't lay them or store them flat.
  • soundfreak1soundfreak1 Posts: 2,775
    Vertical pack not horizontal.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    YAMMY cdp
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • pitdogg2pitdogg2 Posts: 8,301
    Hello go to the local 711 and steal all their milk crates out back.....
    It's what we did in the late 70's....
    edited January 14
    ^^ they resized those 70s milk crates. They no longer fit Lps these days! ^^
    Polk SDA1c modded
    Yamaha YP-D6
  • Viking64Viking64 Posts: 1,066
    edited January 14
    MrBuhl wrote: »
    That is somewhat true. Although they don't fit "perfectly" as they once did, you can load them in such a way (angled) where you can get about 70-80% the number of albums in them. Plus, they are a bit lighter than if they were full, AND it gives you space to get your hands inside the "handles". win/win/win :)
    edited January 14
    I think they're metric milk crates ;)
    One can still find vintage, LP-compatible milk crates.
    "Chance favors the prepared mind" (as Pasteur observed).
    I like the idea of the boxes from the H.D. or the Sleeve City boxes. It's a 5 hour trip from Chicago to St. Louis. The move is less than a month away so, barring some freakish heat wave in February, heat is not likely going to be an issue. Thank you for all the replies! Much appreciated!
Howdy, Stranger!
