Some Winter Projects
Just finished up a couple of Winter Projects. Built a new TT Rack and moved it to side of the room, had a pesky Heat Vent above the Table in the former position, spewing out Dry Air and Dust. Lowered the Center Rack also, this has helped clean up the Center Image a bit.
Also finished up a pair of CRS+'s, just received back the X-Overs from "The Man" Dave yesterday, have them hooked up and playing Music. I can't get over how much sound comes out of these boxes! Accompanied by Rythnik F8 Subs, the CRS's sound really, really good!
I stripped the Vinyl covered cabinets and Veneered with a Birds Eye Maple, some Cherry Stain and a few coats of Clear Poly later.
Let the "Burn In" begin ;)
  • dkfreebird
    dkfreebird Posts: 1,180
    That looks awesome. Nice job.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
    Clipdat Posts: 12,559
    Sometimes I see plants near speakers, is it a type of acoustic treatment?
    Room and speakers look great, I immediately want to bring over several records to test everything :)
  • aprazer402
    aprazer402 Posts: 3,087
    Very beautiful room Mike!
    EndersShadow Posts: 17,517
    So are you running XLR from your TT to your preamp? I’d love to see how everything’s connected as it looks super cool!
  • Mike Reeter
    Mike Reeter Posts: 4,314
    Thanks for the Positive comments, yes I do all the House Keeping as well :) my Phono Preamp doesn’t have Balanced Outputs, so I have some Audio Sensibility, 5 meter RCA I/C’s to the Linestage Pre.
    I can not hear any signal loss from the TT’s previous location, moving the TT and lowering the Center Rack has really cleaned up the Imaging, I might end up with all the gear in the new Rack and just have the Amps in the center.
  • Mike Reeter
    Clipdat wrote: »
    The Plants are for astetics and color! Can’t tell if they bring anything else to the table. Bring your LP’s and I’ll have the Refreshments ready!
    Wow, I figured 5m RCA's would cause some issues. Good to know its not the case (as I'm potentially headed that route shortly lol.....
    You also have me wondering if I shouldn't do the same thing for my setup and leave my 5 channel amp, and my 2 Crown amps in the middle and then locate all my source gear in the corner out of the way. Would free up some space for a project I'm working on. Then I'd just XLR from my preamp to my B&K and Crowns and be good.
  • ken brydson
    ken brydson Posts: 8,638
    Gorgeous! Wish I could pull off something like that!!
  • Mikey081057
    Mikey081057 Posts: 7,127
    That is very beautiful Mike... Congrats well done..
    Garage | Polk Monitor 5B's
  • Conradicles
    Conradicles Posts: 6,010
    Great job Mike! Bet that room sounds fantastic.
  • Mike Reeter
    Sounds like a plan, I did a “test run” before I decided to make the move, and liked what I heard, so I proceeded to get to work. I’m going to try moving the Linestage and other gear to the side next and using the long I/C’s from the pre to the amps and see what that brings.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Awesome looking setup Mike. Still need to get down there to visit first hand!
    txcoastal1 Posts: 13,124
    Looks great
    Do you still have the Dyn's?
  • A beautiful room and set up. Plus, I'd love to hear construction details on the equipment racks, as they look awesome! Nice job.
  • vmaxer
    vmaxer Posts: 5,116
    Very nice, love it.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Mike Reeter
    txcoastal1 wrote: »
    Looks great
    Yes, I just like to play around, Love that SDA sound too!
    gudnoyez Posts: 8,056
    Great looking room are they 4.1TLs? I love the venner job looks great.
  • Thorton
    Thorton Posts: 1,324
    Nice job. Looks great and the room is beautiful too.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Mike Reeter
    Thanks again, everyone! The CRS+'s have the 4.1TL Upgrade, they are amazing! I had a previous pair with the 4.1TL Upgrades, and like the Fool that I am, I sold them! I came across another pair and decided to turn them into "keepers"
    I've been working on the Room for over two years, it's always been a "Work in progress". I'm an extreme amateur at working with Wood, but I enjoy making pieces that incorporate into the Audio Obsession :)
  • Mike Reeter
    ZLTFUL wrote: »
    Ryan, the door is always open to you and any other CP Members that might be passing through the Midwest. The Tubes are always warm and the Beer is always Cold!
  • machone
    machone Posts: 1,471
    Nice!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • verb
    verb Posts: 10,176
    Beautiful job on the cabinets Mike !!!
    Can you share some details on the acoustic wall panels? They look great too !!!
  • Mike Reeter
    edited January 2018
    verb wrote: »
    The Panels were also a DIY Project, made out of 1"x2" Frames, mine are 2'x4' and 2'x2', filled with Corning 703 Rigid Insulation, which comes in 2'x4'x2" sheets.
    I just finished the Bass Traps a few months ago, they took a little more effort. Very simple stuff, bought the 703 and the Burlap Covering from https://www.atsacoustics.com/
  • westmassguy
    westmassguy Posts: 6,850
    Very nice Mike. The maple looks beautiful on those puppies.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mike Reeter
    Thanks David, your X-Overs fit like glove! And are sounding very good!
  • chumlie
    chumlie Posts: 8,658
    Awesome looking room.
  • scubalab
    scubalab Posts: 3,101
    I have to agree with others, Mike. That Bird's Eye Maple veneer on those CRS+'s looks absolutely amazing! Very nice room.
  • MrBuhl
    MrBuhl Posts: 2,419
    Really beautiful room and rack - I'm a sucker for Birds Eye, I have it on rifle stocks, guitars, and someday - speakers like those, just really stunning!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Mike Reeter
    Thanks again for all the positive comments! I started disassembling the 3.1's today, going to give them a Facelift also.
