Wall mounting a LSiM 706C
EarthyEarthy Posts: 484
edited January 10 in Speakers
Looking for an idea. Thinking of a wall mounted shelf that can hold the 46lbs and look good. It would need support from below as the TV would be just above it.
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
  • afterburntafterburnt Posts: 4,428
    big lag bolts
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • DaveHoDaveHo Posts: 1,927
    rpf65 wrote: »
    I used this same mount for my wall mounted turntable platform. I can vouch for its quality. It's solid.
  • EarthyEarthy Posts: 484
    Nice, I see it on Best Buy for $35. Hard to beat. My speaker centers about an inch from a stud. Might need to put a 3/4 hardwood board across three studs so the mount can be centered and anchored well. I should be able to get long lag bolts in the center stud. Thanks all!
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
    I stumbled across this one on Amazon. Might work better for me since it's two brackets. Rated for 110lbs so no issue there. http://a.co/h4HhLHY I can get it faster than the other one so worth a try at $29
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • rpf65rpf65 Posts: 1,737
    I use the one I suggested for my LSI M706C. Build quality is very good, mounting options seemed a little bit more versatile than the style you suggested.
    Did you add a shelf? Are there options to anchor a shelf to the arms? Looks nice but over a week to get.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • GlennDogGlennDog Posts: 1,514
    Earth,
    What's a fair price for a "used" 706 center? and how do you rate it?
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Definitive Technology BP-2
    DAC North Star Design Supremo
    Source PSA PWT & Oppo 105
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Pre Cary SLP-98 F1
    Center Salk HT2C
    Wires MIT S3.3
    PSA PC AC-12
    With all the recent adorama sales, I think new ones can be had for $5-600. I have not sold used speakers before. Usually give them away or store them. I am not the expert at rating speakers. Hopefully someone will chime in. Perhaps you should start a new thread.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
Howdy, Stranger!
