Will this amp work for my LSi's?
I found this amp on eBay, it is a adcom GFA-5300, will it work to power these speakers?
https://www.ebay.com/itm/ADCOM-GFA-5300-Power-Amp-80-W-8-Near-Mint/253342956915?epid=66783596&hash=item3afc6abd73:g:v9QAAOSwBRFaTDqm
Thanks for any help, micah
2 channel
Speakers: Mission 770 Freedoms
Integrated amp: Technics SU-v75 and matching tuner
CDP: Technics SL-PC20
Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
TT: Technics SL-3200, direct drive
Cartridge: Shure M97xE
Pc gaming setup
Receiver/amp: Yamaha RX-V665
Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
Speakers: Boston Acoustics CR75s
Random equipment on standby:
Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
txcoastal1 wrote: »
You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
Seen somewhere on AudioKarma (I think)
  • UpstatemaxUpstatemax Posts: 2,207
    What LSi's do you have?
    Living room:
    Samsung PN50B860 50" Plasma : XBOX One : Roku 3 : Oppo BDP-103 : Pioneer Elite SC-87 : APC H15 : Focal 806V mains : Focal 806V Surrounds : SVS SB2000 : SVS SB12-NSD
    2Ch:
    Sonus Faber Venere S : Parasound HCA 1500A : Oppo UDP-205 : Furman Elite 15 DM i : Sony XBR 55X810C Monitor :
  • mlistens03mlistens03 Posts: 986
    LSi25s, sorry I should have specified that. This amp is the one suggested by tonyb:
    http://www.usaudiomart.com/details/649391951-parasound-hca1200-power-amp-205wpc/
    THis one is more powerful, but it is like s $300, and I would have to save for a long time, so if I can get this one for way cheaper and have it work I would like to.
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • cfrizzcfrizz Posts: 12,905
    Will the Adcom work...of course it would. Will it power your LSI's to their full potential...not even close!
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  • Airplay355Airplay355 Posts: 4,153
    Looks like the auction ends in 4 min so you'll probably not get to read this in time but I'd just wait for something nicer and more powerful. I suspect you'd like the Parasound WAY more than the Adcom.
    However, it also depends on your listening habits. If you like normal listening levels (like you could still talk with music on in the room) the Adcom or similar might be just fine. It won't be the best but shouldn't be something you immediately regret. If you like turning it up to 11 then avoid the Adcom and similarly powered amps. You're going to really have to push it to get what you want.
    If you've already bought it though, then congrats and don't worry about it! If its just what you needed then great and if you don't like it then it's all part of the audio journey, someone else will buy it no problem.
    Ok. I didn’t buy it, I didn’t realize it ended. Also, a pair of infinity speakers I’m going to sell turns out to be worth a lot more money than I thought, so I can get an amp for up to (estimating here) $500, any suggestions?
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • tonybtonyb Posts: 29,026
    Yeah, the one you posted, the Parasound. You won't find a better amp for that price. Take the extra coin and buy decent speaker cables if you don't have any yet.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    I’ve got 16 gauge monster cable my dad gave me and some monoprice 12 gauge pure copper cables, and I’ve got a fifty foot hdmi cable (the definition of overkill) and I have a 16 foot rca cable that is for car audio already. I’m going to see about buying that amp in the future, and if there are any cables you guys think I need, or anything that will not be good enough, then let me know. I’m going for sound quality, not just super loud music, so I want the best. Also, I have a kicker 12” that I found at the flea market for $20 that I am running on that amplifier that went bad since the left channel still works, but will this hurt the quality in any way?
    Thanks so much for all your help guys.
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    I don't understand your subwoofer question very well. Sounds like it's kind of hacked together anyway so don't worry about quality.
  • FestYboyFestYboy Posts: 2,317
    Toss the 16agw, and the HDMI cable, both are useless in this situation. The Kicker sub should stay where it was intended to be: in the car. Flip it for more $. Buy a HT powered unit (assuming this is for a HT build). If it's not, then don't bother with the sub and use the powered, integrated subs in the LSi25s.
    I’m using the hdmi cable with an adapter from my iPad and then into my receiver as my reciever has a better dac than the cheap one in my iPad, but if there is something with this that will hurt quality, then let me know.
    ok, so I’ll drop the kicker.
    This is mostly just for stereo however if I find a good pair of surrounds I might hook 'em up. Generally I use my mains (not the polks since I don’t have an amp yet), my center, and one of the Polk subs. I would use both subs, but the right one doesn’t work and I gotta get it fixed, but the power amplifier comes first so that I can actually use my speakers.
    I also have a Velodyne ten inch powered subwoofer, should I hook this up as well because I have it? Or is it not going to help a lot?
    And one more question (sorry, this is a long post) what is wrong with the 16agw cable? It is pure copper, and I’ve used it for a while now, and I haven’t noticed any difference in sound when I started using the monoprice cable. I’m not saying your wrong for saying why I should get rid of it, I’m just wondering, what is wrong with it?
    Thanks again for all your help.
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
Howdy, Stranger!
