Building my own Audio/Equipment Rack
13»
  • Toolfan66Toolfan66 Posts: 13,825
    edited November 2011
    carvcom wrote: »
    Very nice work Larry, I love seeing the work of a skilled craftsman.
    You will be enjoying those for many years!!
    Thanks!!!
    You do know we should hook up someday, Our shop is in Thornton..
  • amulfordamulford Posts: 5,198
    Damn, Larry. They are beautiful. I like the two different paint styles, it really sets off well with the acrylic.
    You could make a bundle off of those, you know...
    I smell ****, burning ****, glowing cherry red spanked ****.
    RT1
  • F1nutF1nut Posts: 40,179
    I'm bringing this back to life because I missed it the first time around.
    Larry has a nice rack ;) :p B)
  • mikeyb128mikeyb128 Posts: 2,735
    I'm all about racks :sunglasses:
    2 channel:
    Theater:
    2011?? Time goes by so fast...
  • BlueBirdMusicBlueBirdMusic Registered User Posts: 285
    WOW!!! Are you working on a Saturn rocket now?
  • msgmsg Posts: 4,258
    edited May 2017
    holy...
    This was before my time. That turned out beautifully. Enjoyed the progress photos with all the accuracy and such. Bery, bery nice.
    Toolfan66 wrote: »
    So I took down my system, and had the gold vein blasted off, repainted it a white black vein, I also replaced the gold spikes with brushed nickel spikes, have to say I’m liking the change..
    What are the wings for?
    And here's a photo of one of Larry's other, more modest, projects.
    The left side hold my DAC on the other side holds the remotes and what ever disc I might be playing..
    TT is coming up after a couple cable moves..
  • mrbironmrbiron Posts: 4,811
    It looks cheap.....build a more expensive one and sell that hunk of metal :p
    The shelf supports are sharp in that color. Don't think we got to see that the first time around.
    How heavy is that remote on the top shelf that it needs 1" acrylic to support it?!?!?!?!?!
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
  • gp4jesusgp4jesus Posts: 1,161
    Toolfan66 wrote: »
    B-E-A-Uti-ful! I'd like 3 stacks: 2 3 high w/the 4th centered, 4 or 5 high. ~$3K which I don't have. Oh well I CAN dream
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
    a 4-5 high stack w/ 3 or 4 wings on either side would work too. Too rich for me unfortunately.
  • Moose68BashMoose68Bash Posts: 3,540
    Beautiful work!
    Bravo!
    Family Room, PS Audio PW Transport, DirectStream DAC; AQ Sky XLRs, Perreaux SM6 MKII Pre; AQ Sky XLRs, Perreaux Prisma 750 Amps or CAT 600.2 Dualmono Amp, Morrow SP7 Speaker Cables, SDA SRS 1.2tls (RD0198s, Dreadnought, Black Hole 5, Acousta-Stuf, Dynamat Extreme, JBWeld. Vr3 Mods: "The Abbot" Monastery-Level Xovers, Custom Internal Wiring, Binding Post Plates, & SDA ICs).
    Exercise Room, Wadia 171 iPod Dock, PS Audio PerfectWave MkII DAC, AQ Sky XLRs, Perreaux SM6 Preamp, AQ King Cobra RCAs, Perreaux PMF3150 Amp, Dreadnought, Supra Rondo 4x2.5 Speaker Cables, SDA 1Cs (Vr3 Mods Xovers).
    Synology 713+ NAS on Gigabit LAN serving PW MkII DAC & DirectStream DAC.
  • And now for a low tech model.
    Home Depot 59 dollar special, with a venetian blind backing, zip tied to the back of the top shelf.
    I have a retractable faux wood backdrop which one can feed wires through the slats and back.
    It slides really easy out of the way, so I can reach the second rack hiding behind the heavy winter curtains that I hung across the area by way of a spring loaded rod.
    I load all of my extra gear on the hidden rack for easy retrieval, when I want to switch out components.
    It's economic and saves space.
  • Awesome craftsmanship there. Very impressive. What kind of pads are those supporting the acrylic platforms? Do they further dampen/isolate the platforms?
  • 250GTLusso250GTLusso Registered User Posts: 160
    Absolutely gorgeous! Jesse, thank you for bumping this thread. Wow!
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • Tony MTony M Posts: 5,855
    I wonder if Larry is still using that beautiful record cleaning machine he built. That was VERY NICE too!
    What imagination and skill. I know Larry adapted a similar rack for his rack and upped it a notch or three. But that record cleaning machine I believe came from him alone. Also, Larry's rings are legendary here!
    I purchased Larry's Rings for ALL my speakers last year (yikes! must have been 50 pounds of steel in those boxes). Still need to install them.
    HT
    2 Channel (Office)
    2 Channel (Garage)
    @Polkaguy58 , I like your rack! You inspired me to go to Costco last night and purchase their commercial rack ($89) which is a little bit wider. I have some left over 18"x18" travertine tile from when I had the floors done that I am going to use to place the components on in the rack. I'll send some pictures when I get it done.
    This is for a temporary rig in the living room while I work on trimming out the Bonus Room upstairs (doing baseboards and crown molding in there).
    HT
    2 Channel (Office)
    2 Channel (Garage)
    edited January 9
    Tony M wrote: »
    I do still have it, just used it this last weekend..
    http://forum.polkaudio.com/discussion/96700/diy-record-cleaner-with-a-technics-tt/p1
    Where does the time go??
    Post edited by Toolfan66 on
  • HermitismHermitism Posts: 1,899
    WOW! I miss so much here by not reading every thread. Larry, your stand is seriously amazing. I don't own a piece of equipment worthy to sit on that rack. A+ Will the acrylic scratch easily by using the wing for sitting remotes and CD cases on or is it hard like glass? I've never handled acrylic before, that I can think of.
    2.0 - Marantz NA8005 | Polk LSiM703 | PS Audio: Duet, Power Port Classic, PerfectWave AC5 x2 PC | Wireworld Equinox 7 IC | Sanus UF30 | OC703 Panels
    6.1 - Pio Elite SC-05 | Pio BDP-51FD | Polk: RTi8, CSi5, F/Xi3, CSi3 | HSU Research VTF-2 MK4 | Monster HTS 5000 | DCF124BW x3 SC | Pangea: AC-9SE x2, 14SE, 14 PC | AQ Chocolate x2 HDMI | M850SW | PS Audio Power Port Classic x2 | OC703 Panels
    edited January 9
    Wow, 4 years.
    I'm glad you're still using that beautiful machine! :)
    Our lives are like a roll of toilet paper. ;)
13»
Howdy, Stranger!
