Is this "Monster Signature Refrence Power Cleaner / surge protector " worth 200.00 ?
Tony MTony M Posts: 6,091
edited December 2017 in The Clubhouse
Here is an Ebay ad of the same .
Any opinion on this thing would be appreciated .
After posting this, I said to myself, I should go to the web and check if there are any reviews. Sure enough, Amazon had a couple with some follow-up comments. I don't like what I read. This might be 10 years old and already blown or ready to, even though the lights are on.
If you think it's a good risk if I get the person to prove it passes power, reply for me.
https://www.ebay.com/itm/312024756274
  • rpf65rpf65 Posts: 1,760
    Not a fan of Monster products for various reasons. There are much better products out there.
    I vote look elsewhere.
  • ClipdatClipdat Posts: 4,725
    Speaking of Monster, look at this honking monstrosity.
    https://sfbay.craigslist.org/eby/ele/d/monster-mpachannel-home/6393864363.html
    Got Dayens?
    Is that some new, overpriced beer I haven't heard of?
  • mikeyb128mikeyb128 Posts: 2,745
    Clipdat wrote: »
    A friend of mine had one of these. He ran a 5 channel lsi set up off one. We frequently saw the clipping light come on during heavy movie passages. Monster is junk.
    2 channel:
    Theater:
  • Tony MTony M Posts: 6,091
    Thank you all for letting me know to pass. ;)
  • ShizelbsShizelbs Posts: 7,424
    I've done just as well for my uses with much cheaper products.
  • obieoneobieone Posts: 5,056
  • mantismantis Posts: 15,010
    edited January 8
    All these power companies do a fair to good job. If you have dirty power in your area, a good quality surge Line conditioner makes a huge difference in retaining your systems performance. Again these products do not make your system better, they retain the abilities of what your system can do.
    For $200.00 your not going to get a very good quality unit. They usually start getting good around $399 and up. What your willing to spend and what they cost could be very 2 different things.
    The Monster products I have seen failures. I don't think they are very good units. Some of them are good quality and I have seen them perform very well but I have also seen them not protect and not clean up the noise floor.
    The HTPS7000 is a very fine unit. I have owned one and it works really good. yes it's worth $200.00 used as long as it's MOV's have not been compromised. Over time MOV's get worn out and the surge section of the unit doesn't perform as well.
    Dan
  • F1nutF1nut Posts: 40,391
    So, if they can't make a system better then what difference does the ability to clean up the noise floor make?
    edited January 8
    I know I def. need a better power outlet design. I'm now using a cheap 5.00 power-strip. Blasphemy, I know. :s
    I'm def. listening to all advice given here! Thanks!
    I do plan to get my act back together this year. ;)
    edited January 8
    This is something I'd eventually like to address in my system as well. I'm currently using this: 61aD-R1RovL._SY450_.jpg
    Tony M wrote: »
    Got Dayens?
    Obligatory:
    gjx1b.jpg?a420912
    Got Dayens?
    Yup. We admit it in advance.
    edited January 9
    Wow is right. I like the clear outlets though.
    Rhodium plating must be expensive. ;)
    I really need this one though. :s
    https://www.tweekgeek.com/furutech-e-tp4/
    I have an industrial quad box made by some quality Co. but one of the double outlets doesn't work. I looked into it and saw NOTHING wrong BUT there were some resistors in there that must be broken. I've yet to diagnose them since I am a embryo in the world of electrical problem diagnosing.
  • DSkipDSkip Posts: 14,887
    Any interest here in Mudra Akustik? I've been in talks about importing his gear as I like the design. It's modular so you can add on what parts you want to.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    edited January 9
    I don't know what that is but it sounds expensive based on how "acoustic" is spelled.
    DSkip wrote: »
    Got Dayens?
    Clipdat wrote: »
    DSkip wrote: »
    Those definitely are Medical Grade power distributors! I guess if we have to ask how much they cost, we can't afford them. :(
  • shawn474shawn474 Posts: 2,811
    edited January 10
    I have a Panamax M8-AVPRO you can have on the cheap if you need it. Nothing spectacular but better than nothing I would think. If you have a use for it and are in need, PM me.
    Shawn
    Pre-Amp: Marantz AV-7005 Pre
    Amp: B&K AV5000 Series II
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    Television: Samsung LN46B640
    DVD Player: Sony BDP-S1000ES
    edited January 10
    shawn474 wrote: »
    Thanks Shawn. But I'm pretty sure I have a Panamax similar to yours but a 4 or 6 outlet strip. Thanks for reminding me. I have so much stuff, things get buried or hidden behind something else and my memory has been challenged the past 10 years. :(
    I found 2 subwoofers about a year or less ago I forgot I owned. One was in the front room against the front wall. The other in the back room against the back wall. Now that's bad! And they are nice subs too!
    But you did remind me to look for that OK Panamax outlet block I have. I think I know just where it is. Man!, I think I'm using it to hook up new to me electronics. It didn't get used too often except for the past couple of months. I bet it is a Panamax! I'll find out after a while when I go out there to put my battery charger back inside.
    edited January 10
    I just looked at my testing power outlet strip / pad and it is a Belkin Surgemaster. It's nice and the LED's arent flikering so maybe it has some life in it. But as a main stereo power outlet strip, I don't know. :#
    I've always thought the coaxial and phone line "protection" on these things were so stupid.
    The one time back in the dial up days that I actually tried running the phone line through it, I got random disconnects and packet loss.
    I believe it does more harm than good to ever run your cable or telephone wires through these things.
    Tony M wrote: »
    Got Dayens?
    edited January 10
    I always wanted to run cable and phone through a surge protector but have read from years ago, Surge protectors of any kind rarely work on a direct hit.
    I have ALWAYS unplugged my stuff when a lightning storm is predicted. That's the sure way of getting protection unless the bolt jumps out of the socket and hits the equipment that way or something like that.
    I'll be unplugging my stuff out in the cave tommorow because we're scheduled to get a lightning storm tomorrow night or Fri. . Lightning hits close to my house once a year at least. So far so good.
    I just heard a transformer blow in the distance. I hear them ALL the TIME. Ours at our pole blew one time. A squirrel I think caused it or I'm getting the 2 events mixed together. The squirrel was turned to a carbon shell. I doubt and hope he didn't feel it. I saw the line-man toss the shell of it off of the transformer. :#
    It's been 16 min. and I just heard a closer transformer blow. It's Crazy.
  • verbverb Posts: 3,352
    Whoa - Lighting in January @Tony M ? Where do you live?
    Basement: Polk SDA SRS, Micro Seiki MB14 TT, VTL 2.5 Pre, Marantz CD6006 CDP, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
    Spare Room: Dayens Ampino Integrated, Auris BluMe, Polk TSi200's
    Living Room: Pioneer SX-N30 Network Receiver, Pioneer PD10AE CD Player, Furman M8-LX Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi Subwoofer
  • pitdogg2pitdogg2 Posts: 10,845
    Not only do they rarely work on a direct hit, most will drop the signal anywhere from 1-3db that can be enough to really furbar the signal at the display. On my OTA tower antenna i bought lightning arresters that the inside house cable/Dish went through at the grounding block. They didn't drop signal at all but like a fuse went toast before anything made it to the TV or am/fm tuner. Parts express sold them cheap enough I'd buy several at a time. My Dish Network guy turned me on to them after he about pulled his hair out trying to figure my loss of signal at the box. When he seen the cable going through my surge suppressor behind the TV stand he was like dude why didn't you tell about this a half hour ago... whoops lol
    edited January 14
    verb wrote: »
    Wilmington NC.
    The lightning didn't come over my house this time. I heard some bad thunder rolls but never heard a crack of lightning. It must not have built up strong enough. But man did it pour.
    Storms come up the coast from the gulf all the time.
    It retains the ability of the equipment.
    Dan
    mantis wrote: »
    Want to try again?
    Tony M wrote: »
    verb wrote: »
    Wilmington NC.
    Better than freezing your arse's off in SE Michigan !!!
Howdy, Stranger!
