Shop progress...
steveinaz
The 16 x 24 shop is done, now I'm insulating, sheathing, and building the storage loft (24 x 4):
Now I need to build a workbench, and 2 - 72"hx48"wx24"d storage shelves.
PS: The pool just needs plaster and fill! I'll post pics when it's filled. This coming Tuesday is plaster/fill day.
Looks great!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
If my back yard had room on the flat area, I'd seriously consider building one of those. Looks great Steve, can't wait to see the pool.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Great looking shed! When I built my workbench I bought a granite look Formica countertop at Menard's. It works really well and easy to clean.
Nice, dude.
Hey, I gotta build some shelving in my garage! Wanna come help?
It's a bit bigger, though.Expert Moron Extraordinaire
Nice Steve, how much did that det you back and where are you in AZ?
afterburnt wrote: »Nice Steve, how much did that det you back and where are you in AZ?
Down in Sierra Vista. The shop cost with options (windows, 50amp ckt, all outlets ran + a 20amp dedicated outlet, and lighting) was $16k. I spent about $600 on insulation, and the loft lumber/hardware was maybe $300. Sheathing is 9/32" and probably will end up being about $250 to do the interior walls.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Very nice...
Dang, I am gonna have to bare bones mine and hopefully live long enough to finish it. And dang AZ is big, you couldn't be further away from me unless you were in MX lol. -
We're about 15 miles North of Mexico.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Ah, that explains the wall around your pool. -
Looking good!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
