Sunfire TGP 5 display issue
Hey guys,
I have a Sunfire TGP 5 that I purchased new a few years ago. It has been great with no issues.
The display is very dim for some reason, and I thought someone here may have ideas of how to fix the issue??
The dimmer works and I have cycled through all settings with it and on the brightest I still can't see it unless I walk up very close to it.
Is there LED's or something that can be replaced fairly easy??
Thanks for ideas.
Thanks for ideas.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
0
http://thecarversite.com/yetanotherforum/default.aspx?g=forum
The best way to enjoy digital music reproduction is to never listen to good analogue reproduction.
I went over and signed up and posted the same thing.
Pretty sure I had signed up there before but couldn't remember login info/
Hopefully someone will know how to address this issue.
Thanks a lot.
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
http://www.flannerysvintageaudio.com/
