subwoofer carpeting
evhudsons
Does anyone have suggestions were to get subwoofer enclosure carpeting that would match the carpeting in the car? I'm sure it's fairly standard black or dark grey carpeting.
My car is a Porsche 911 997 if that makes any difference.
Post edited by evhudsons on
I picked up some from a local car audio install shop. It's nearly a perfect match for the light grey carpet in my '95 Trans Am.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Believe it or not, Wal-mart used to sell some small rolls of auto carpet, they kept it by the steering wheel covers.
Fabric store may have some carpet in the color you wish.Receiver: Denon 1912
Speakers:
Fronts: Polk Audio Monitor 70s (x2)
Rears: Polk Audio Monitor 50 (x2)
Center: Polk Audio Monitor 70
KLH Sub GFX-550 -
Can you give some details of the fabric stores? It would be very helpful. Thanks in advance.Try this website
I didn't get the reply yet. What will be the other works done by the stores? Anybody help. I need it urgently.Try this website
I've used outdoor type carpet from Lowe's and it matched really well.
try joannes fabrics, or walmart, or a car stereo shop2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know "WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA
Just find an automotive interior shop in your area. Company called Ozite offers just about every color and texture to match OEM carpets and trunk liners.
Holy necropost Batman. -
ken brydson wrote: »
Post T-day drinkin' will bring these up from the dead on occasion. -
As long as the carpet matches the curtains, you're golden...
Lightweights. The full duplex Vadic 1200 bps is tops, and was invented by them. Four times as fast as the previous 300 bps modems at the time. Testing/fixing Vadic modems was my first job in CA when I moved here in 76. Computer networking has been a good career for me.
Three 20 amp circuits. -
This dude that I know owned a used car dealership. He told me he would pull the carpet out of cars, shampoo it, dry it and then spray it with spray paint. Wonder if black spray paint would do ? (Tee Hee)
