2B's Más Huevos
Brian did you spray paint the inside or is that something else you applied? Looks good by the way.
Thanks, I brushed on 2 coats of cheap paint from Lowe's.The Night is Dark and Full of Terrors -
stainless0steel2 wrote: »
I just may steal that idea next time i have mine apart. -
Hey Brian, I guess I should have asked is there even a brace between the midwoofers to measure?
The repurposed JBL cabs I saw had a thick coat of roofing polymer brushed on the inside.Don't take experimental gene therapies from known eugenicists. -
@stainless0steel2 PM sent.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
Yea there's a 9.25"x9.25"x.75" brace. I beveled down the top edges for a little extra clearance for rings. I wish I'd done something completely different while they were out. But that ship has sailed...
Well I'm closing in on finishing theses things.
I made a template at work for these deals I'm using to mount the board.
Mounted the 16mh inductors
Clean
I like the wire wrap and shrink job you did in the cabinets2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I like the hardware you're using, and I also like the wire wrap, I want you to share that with me..
I'm not sure I like the paint in the cabinets, I think if it was textured it would look better, but I'm not sure if the texture would change the sound..
Looking forward to hearing them, and what your thoughts are when you're done with them.. -
This thread proves the moderators no comprende Espanol.Don't take experimental gene therapies from known eugenicists.
I'm still looking forward to how the eggs are incorporated--always looking for ways to improve my 2BTL!Jay
"Huevos" in Mexican Spanish (which is mostly slang) refers to having guts or balls.The Night is Dark and Full of Terrors
Jay
Very cool. Reminds me that I've got a full set of Jantzen inductors to put in place of the stockers.
May I ask how you secured the SDA inductor to the floor? That's the one detail I haven't worked out yet. (Is that a Northcreek inductor?)Jay
I believe could be a Solen. I do not know if Northcreek is making any these days. Price page is gone and inductor page say's "retired2016" at the bottom.
They're Northcreek. I bought them off of Larry awhile back.
I'll take some pics when I get home. Mounting the inductors turned out to be really easy.The Night is Dark and Full of Terrors -
Solen makes an air core 16mH 14AWG inductor PN# S1416.0.
https://solen.ca/products/inductors/standard-inductors-14awg-1-63mm/s1416-0/Post edited by TNTsTunes on"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
stainless0steel2 wrote: »They're Northcreek. I bought them off of Larry awhile back.
Interested as well in the way you mounted as well. post up some pictures Yep if I would of read that second picture it says northcreek right on the box lol -
Just make sure the screw or bolt is non-magnetic, either stainless, brass or even aluminum.Home Theater/2 Channel:
dhsspeakerservice.com/ -
2bTL's eres muy guapo!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
So I used these t-nuts and some stainless all thread that welded at the bottom. Then these plastic spacers that I made fit into the center and that's what holds this whole thing in place. Plus I added a rubber gasket for them to sit on.westmassguy wrote: »Just make sure the screw or bolt is non-magnetic, either stainless, brass or even aluminum.
Nice JobHome Theater/2 Channel:
stainless0steel2 wrote: »Mmmmmm... anodized...
Man Brian those are super nice binding cups great job on all that. -
So pretty you may want to run the speakers facing the wall.Jay
Órale vato! Those are nice ese.
All done! These things sound incredible!!!
Huge thanks to @gimpod for his guidance! As well as Larry @Toolfan66 for hooking me up with the anodizing and miscellaneous parts!
