DIY Ultrasonic Record Cleaning Machine
13»
  • jonicont wrote: »
    Got my unit. Fit and finish is excellent. However, it seems that the on/off switch was installed upside down for a number of us.hu5mdwz1em8r.jpg
    Heated up a gallon of wash (I'm using TergiKleen) to 110F, poured it in the tank and added another 1/2 gallon of room temp wash which brought it to 96F. Pulled out a record that hadn't been played in 20 years and ran it through the RCM first.ys9f41v48fmg.jpg
    Sounded pretty nice with just some scattered crackling and a click here and there. Put it through the US bath and it came out perfect!
    Also cleaned a relatively new record that inexplicably developed crackling on the first 2 songs.
    Was not removed by multiple runs through the RCM. The US bath took care of that problem!
    I do a rinse on the RCM after the bath
    All in all, I'm very pleased with the product. Thanks Brian
    I'm glad you like it! You'll eventually get to the point where you'll never let your stylus touch a record that hasn't been ultrasonically cleaned.
    "The Night is Dark and Full of Terrors."
  • msgmsg Posts: 3,605
    edited April 2017
    Finally got around to building out my kit the other day. Only cleaned a few records at this point, but really enjoying it so far. Still messing with my process and need to catch up with you other guys to get settled, and do some more critical before/after comparisons. Here are a few build photos. (the heavy gauge power and ground wire shown in the top right are there just for a laugh. was in my wire supply. I didn't really try to use that for the switch. but mostly only bc I didn't have any wire nuts big enough :p )
    VARIOUS
    ELECTRICS TEST FIT and FINAL MOUNTING
    A big thanks to @ER308L for pulling these kits together for us, and to @voltz for the hand holding (ha) during finishing parts and materials acquisition, cleaning solution mix, unit setup and configuration, and cleaning procedure tips. Was able to skip a lot of trial & error, which saved me a lot of time. Thanks for this opportunity, Brian - no way I would have been able to pull a DIY USRCM together on my own!
  • voltzvoltz Posts: 4,702
    Nice Layout of pictures Scott! Now lets get some more cleaning done :p
    I'd send you box full of mine if the shipping cost wouldn't be so high.
    I'm just glad I don't have as many Vinyl as Red does.
    I didn't know what to expect when I first ran the ultrasonic. I was trying to explain the project to a friend, and he said, "Sooo, you're cleaning something you listen to with something you can't hear."
    I told him to shuddup.
    Turns out it sounds a lot like this. Minus the guys buzzing about aimlessly in circles.
  • txcoastal1txcoastal1 Posts: 8,633
    edited April 2017
    ^^^^^I loved that game
    Right up there with Rock'em Sock'em Robots
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
    That needs an lol, as well as a like - how the heck could anyone love that game?!? We'd try it for about 5 minutes and then lose interest and start experimenting. No animals were hurt. But little brothers might have been rented out.
    msg wrote: »
    5-letters my friend... BB-Gun ;)
  • muncybobmuncybob Posts: 1,703
    OK, so we can clean records with US units...how about drying clothes too!?
    http://www.dailymail.co.uk/sciencetech/article-4428576/Ultrasonic-dryer-shakes-clothes-halves-drying-times.html
    Yep, my name really is Bob
    That was actually a neat read. Interesting!
    I'm waiting for Brian to figure how to dry them too ;) I have faith in you!
    voltz wrote: »
    Speaking of Friday night...
    Welcome to the weekend!
    Clean 'em up, and crrrank it up!
    edited April 2017
    I currently have no Phono amp cause mine is boxed up heading to Kev's house for a 3 week trial :) so I'm all digital for a few weeks. but I can still clean some Vinyl ;)
    You are dead to me.
  • voltz wrote: »
    Funny you should mention that. I found these in one of the laser scrap buckets. So many possibilities. It's definitely going to be in the shape of a box, that's for sure. But I desperately need to build a new media center; I'm completely out of room. So this will have to be put on the back burner.
    My GT Sonic has arrived but timing is bad. We just gutted our kitchen for a total make over and stuff is spread out everywhere...no room or time to clean. I'm just itching to do this but with crap all over the place I can't listen to anything even if it was cleaned.
    I will say the US unit is heavier than expected...a good thing I hope! I'll probably do a foil test just for giggles.
    Baaah.
    Good info on the foil test though! I didn't know you could do that. Cool.
    I'm going to get the pipe thread nipple for mine today, and drain, filter, and store my cleaning fluid, since I'm waiting for some brushes. I'd like to run this test as well, since I noticed a variation in action in different areas with two records in the tank.
  • Would love to buy one. Your setup looks like it would hold up better than the others I've seen offered on eBay and amazon. Are you making any more to sell?
  • Yes I will be making more around August. I sent you a PM. Thanks, I agree mine are much better built then others you see out there. Even with the webbing that the 3d printed ones have they're still wouldn't survive a fall to the floor. Where as mine would put a dent in your floor. lol This next go around I've figured out a way with our lathe to accept a larger billet so it can comfortably fit an inner and outer o-ring.
    It's been awhile since I put my hands on my cleaner(life gets in the way around here a lot!).
    Anyhow, due to some miscalculations on my part I am finding that I need to raise the motor and rotating eye piece about 5/8". Although Brian did offer some help he seems to have vanished. I can see how to raise the motor but have no idea how to raise the other end with the pivoting "eye". If I can't figure this out I'll probably offer up my "spinner" for sale and look for other alternatives.
  • Hey, I know this is an OLD thread, and Brian, from the looks of it, is a deleted user..anyone know where I can pick up a kit like this? I want to put together a DIY ultrasonic LP cleaner of my own, without breaking the bank. Thanks for any info you guys can give me.
    Ohhhh Briiiiiii-annnnnnn, yooo-hoooo!
    @stainless0steel2
  • ^Gracias^
    Ok @flyweed my plate is a little full right now. I've got my SDA 2b's I'm finishing up. And I've got this old sewing machine (don't judge) my mom wants refurbished.
    Things seem to be at a manageble point at work where I could pull off another run. I'd like to do it mid to late February. You know the time people start to get their tax returns...
    So anyone who reads this, message me so I can add you to the ever growing list. :)
  • Brian, SO glad you are still on here. Shoot me a message on price, etc. And add me to the list. I'd LOVE to get one. Thanks much. OH and Mid to late February is perfect timing for me. :)
13»
Howdy, Stranger!
